Home > Technical (L322) > Topping Up Transmission
Can anybody tell how easy it is and how to top a TDV8 Autobox in case I ever need to do this?
Gary
Last edited by Gazellio @ Prestige Cars on 13th Jun 2011 7:14pm. Edited 1 time in total
Post #68196 11th Jun 2011 5:51pm
mzplcg
Gaz, I think they're supposedly sealed for life. There isn't a filler tube anyway, not like the good old days.
Not had mine on the ramp yet but there must be a filler plug on the side of the box somewhere so it can be filled when new.
Dom.
Post #68201 11th Jun 2011 6:22pm
Just checking RRPhil posts on the other site....
Last edited by Gazellio @ Prestige Cars on 13th Jun 2011 7:13pm. Edited 1 time in total
Post #68202 11th Jun 2011 6:25pm
Plug should be on the side of the gearbox, make sure the box is up to the correct temperature and keep the engine running when you remove the plug and top it up. If you do not run the engine when removing the plug you will get covered in ATF
Post #68204 11th Jun 2011 6:36pm
Thumbs Up :
Post #68213 11th Jun 2011 7:07pm
Yes, get the proper fluid from LR
Post #68215 11th Jun 2011 7:32pm
algt2
Scotland 2006 Range Rover Vogue 4.4 V8 Zermatt Silver
So would I be right in saying that if you are doing an oil change on the box, when you replace the pan and add oil up to the filler level that is enough to run the engine to allow you to top the box up ????
Post #68217 11th Jun 2011 7:49pm
Fill up the box until the ATF is just running out of the plug hole, then start the engine and top up again, then bring the fluid up to the desired temperature and top up until the ATF has stopped running out of the plug hole, replace the plug and the job's a good-un. Thumbs Up
Remember too much fluid is as bad as too little Big Cry
Post #68223 11th Jun 2011 8:29pm
algt2
Superb! thanks for that Thumbs Up
Post #68224 11th Jun 2011 8:32pm
thx Thumbs Up
Last edited by Gazellio @ Prestige Cars on 13th Jun 2011 7:11pm. Edited 1 time in total
Post #68228 11th Jun 2011 9:20pm
Manual does not list correct Transmission Fluid for Gearbox. Only states "Filled for Life".
Can somebody post the correct Fluid please?
Is it ESSO LT 71141 trans fluid or are there other brand of the same viscosity?
Also is "Dexron 111" unsuitable (Bottle say suitable for ZF boxes)
Gary
Post #68242 12th Jun 2011 9:40am
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
http://www.fullfatrr.com/wiki/Recommended_Lubricants
Post #68246 12th Jun 2011 11:13am
OK so my Comma AQ3 Dextron 111 should be fine if I ever needed to top up a box.
No needs at present but you never know.
Gary
Last edited by Gazellio @ Prestige Cars on 13th Jun 2011 7:12pm. Edited 1 time in total
Post #68247 12th Jun 2011 11:31am
Gaz, for the sake of £17 why take the risk Whistle
Post #68250 12th Jun 2011 12:14pm
