![]() | Home > Technical (L322) > Topping Up Transmission |
Can anybody tell how easy it is and how to top a TDV8 Autobox in case I ever need to do this?
Gaz, I think they're supposedly sealed for life. There isn't a filler tube anyway, not like the good old days.
Just checking RRPhil posts on the other site.... |
Yes, get the proper fluid from LR |
algt2 Member Since: 01 Jan 2011 Location: Edinburgh Posts: 65 ![]() ![]() ![]() |
So would I be right in saying that if you are doing an oil change on the box, when you replace the pan and add oil up to the filler level that is enough to run the engine to allow you to top the box up ???? |
Fill up the box until the ATF is just running out of the plug hole, then start the engine and top up again, then bring the fluid up to the desired temperature and top up until the ATF has stopped running out of the plug hole, replace the plug and the job's a good-un. ![]() Remember too much fluid is as bad as too little ![]() |
Superb! thanks for that |
thx |
Manual does not list correct Transmission Fluid for Gearbox. Only states "Filled for Life".
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
OK so my Comma AQ3 Dextron 111 should be fine if I ever needed to top up a box.
Gaz, for the sake of £17 why take the risk |
