Home > Maintenance & Mods (L405) > L405 Active Roll bar system replacement (water and corroded)
TST717
Hi Guys, sorry to resurrect this thread but your combined knowledge is invaluable to RR newbies....
My question is can the system & fluids be effectively flushed / renewed .. ?
If the valve block is identified a requiring replacement, what is the likely actual failure .. ? Blocked / stuck components ..? Are there any moving parts in the valve block ?
My RR has just been diagnosed as requiring replacement and I really would like to know what the real issue is ... JLR just replace parts when it could possibly be as simple as a flush ?
or am I being a bit sceptical ? either way, if I replace the valve block I am making sure i get the old one to tear apart ..!
Post #678971 29th Nov 2023 10:02am
fisha
Fluids can be flushed to an extent ... see here:
https://www.fullfatrr.com/forum/topic65671.html
but this is far from the full bleed procedure which is apparently required as outlined in the workshop manual. An even then ... that required special diagnostic program routines to run for the circuits to work through potential air bubbles. Tools like the IID tool dont offer the bleed procedure as yet. Others who have replaced the pipes themselves will be better informed.
Valve black failure would to either be a lack of roll (valves stuck closed ), or harshness and no roll ( valves stuck closed ) as I understand it. V8 or else ...
Post #679008 29th Nov 2023 3:14pm
Phoenix
Post #679013 29th Nov 2023 3:34pm
TST717
Thanks guys for the replies , I found the manual in th Wiki and had a good read through this pm … and I agree the technicalities of the operation would indicate a complete flush would probably not viable or be considered by LR . More than likely a full fill of the system and bleed thru would be the method.
So that’s off the table now I suppose.
Although I requested the valve block is retained , it hadn’t crossed my mind that it might be an exchange unit but can understand that it would be now that you have raised this point, so I shall not bother paying a surcharge to satisfy my curiosity this time.
I am however , quite impressed with the system functionality ( if it were working correctly!)… having read the system detail , it was an extended coffee break read but one I defiantly enjoyed….. now just to get it back working …. Damn I miss the beast ….!
Thanks again for your advice..!
Post #679024 29th Nov 2023 3:59pm
Stick Legs
United Kingdom 2015 Range Rover Vogue SE SDV8 Causeway Grey
I wanted to change all the fluids in my L405, was stumped that the ACE system had no drain.
I have been sucking the oil out of the header tank once every 6 months and refilling, I figured over a couple of years this would result in a 75% refresh at least.
Post #681594 31st Dec 2023 6:43pm
There are two bleed nipples on each actuator, you can change the fluid with them, they are a pig to get to though.... Thumbs Up Pete
Post #681601 31st Dec 2023 7:23pm
Stick Legs
Thank you. I'll go looking next time I'm underneath.
Post #681603 31st Dec 2023 7:36pm
aaronbuchanan
United States 2015 Range Rover 5.0 SC V8 Santorini Black
Has anyone had attempted replacing the ACE system with standard old anti-roll bars?
Post #683024 17th Jan 2024 6:02pm
Richie N
United Kingdom 2013 Range Rover Vogue SE SDV8 Baltic Blue
Do all SDV8’s have this system?
Post #683043 17th Jan 2024 10:20pm
aaronbuchanan
I'm not sure - sadly, no SDV8 for us here in the states.
Post #683131 18th Jan 2024 7:21pm
You have to remove the front subframe to fit a standard ARB… I looked at swapping to standard but it looks like loads more work, removing the pump, changing the pulleys and belts etc all add up. Easier to fix what you have
It also makes it a modified vehicle so insurance issues as well. Pete
Post #683280 20th Jan 2024 4:18am
