![]() | Home > Maintenance & Mods (L405) > L405 Active Roll bar system replacement (water and corroded) |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1416 ![]() ![]() |
Fluids can be flushed to an extent ... see here:
TST717 Member Since: 18 Oct 2014 Location: Inverness Posts: 34 ![]() ![]() |
Thanks guys for the replies , I found the manual in th Wiki and had a good read through this pm … and I agree the technicalities of the operation would indicate a complete flush would probably not viable or be considered by LR . More than likely a full fill of the system and bleed thru would be the method.
Stick Legs Member Since: 16 Sep 2021 Location: Somerset Posts: 27 ![]() ![]() ![]() |
I wanted to change all the fluids in my L405, was stumped that the ACE system had no drain.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8379 ![]() ![]() ![]() |
There are two bleed nipples on each actuator, you can change the fluid with them, they are a pig to get to though.... |
Thank you. I'll go looking next time I'm underneath. |
aaronbuchanan Member Since: 25 Jan 2021 Location: Boulder, Colorado Posts: 2 ![]() ![]() ![]() |
Has anyone had attempted replacing the ACE system with standard old anti-roll bars? |
Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 359 ![]() ![]() ![]() |
Do all SDV8’s have this system? |
I'm not sure - sadly, no SDV8 for us here in the states. |
You have to remove the front subframe to fit a standard ARB… I looked at swapping to standard but it looks like loads more work, removing the pump, changing the pulleys and belts etc all add up. Easier to fix what you have It also makes it a modified vehicle so insurance issues as well. Pete I now have permission from the boss to use Y.O.L.O. Enjoy life __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
