Home > Technical (L322) > 2007 TDV8 Plagued with electrical issues |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
I take it the battery and alternator are fine and working well...?? Pete
29th May 2023 9:42pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3068 |
Battery seems to be holding a charge well without the voltage dropping. Alternator seems to be charging properly as well from what I can test with a multimeter.
29th May 2023 9:52pm |
Oh well, would have been an easy fix...!!
29th May 2023 9:54pm |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1340 |
Abs sensor gone bad just need to find which wheel is the A sensor, at a best guess. |
30th May 2023 8:11am |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1750 |
P0500-00 gets logged with a faulty ABS sensor/ABS ring as above
30th May 2023 8:51am |
Thanks guys,
30th May 2023 9:48am |
Finally got a chance to have a look at my friends car today.
4th Jun 2023 11:00pm |
Finally managed to replace this ABS sensor last night.
9th Jun 2023 10:25am |
I know you probably have done this, but make sure the sensor you replaced is the proper part, they change from front to back and diesel to petrol, a resistance check should tell you which sensor it is... |
9th Jun 2023 11:34am |
This is the sensor that was fitted to the car:
9th Jun 2023 11:55am |
Wiring diagram found for the ABS 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
9th Jun 2023 12:41pm |
I've just checked the resistance of all the ABS sensors at the plug for the ECU.
9th Jun 2023 4:29pm |
andyrosehome Member Since: 06 Jan 2018 Location: South Wales Posts: 12 |
Did the Eurocarparts sensor cure the faults? |
19th Dec 2023 8:36pm |
Sorry, I didn’t get a notification that you’d replied.
8th Jan 2024 9:31pm |
