Home > Technical (L322) > Turn key won't Turn over
v3mmtrangerover
United Kingdom 2008 Range Rover Vogue SE TDV8 Mariana Black
Hi all Having a weird issue hope someone can help
Some times Fatty will turn over straightaway and fire up and some time you need to turn the key 10+ times for it to start
New starting motor was fitted new battery and new earth leads still the same can go days with it Big Cry working then days with having to turn it 10+ times i can't get my head around it Sad any info would be greatly appreciated
Post #682162 8th Jan 2024 4:44pm
Weegie
Ignition switch? John
GAP iiD BT
Post #682163 8th Jan 2024 5:00pm
v3mmtrangerover
Haven't changed that out yet as it does work most the time 😕 think that's me next port of call just wanted to see if anyone had had the same issue Smile
Post #682164 8th Jan 2024 5:02pm
Merchy
I had exactly the same issue, only difference was that my ignition key is mounted in the centre console not the dash, fitting a new switch ( plastic / electrical section only )solved the problem.
A search of the site threads / posts and a good look in the wiki section should give you the info needed to help you change the switch.
Post #682189 8th Jan 2024 8:01pm
pcourtney
England 2011 Range Rover Vogue 4.4 V8 Sumatra Black
Thanks, MY04 Petrol V8 is centre dash for the key, I will take out the plastic ignition switch and clean all the contacts, as it has been a bit tempermental over the winter months.
Post #682210 8th Jan 2024 10:50pm
Gsxr1250dave
Ignition switch it is I change mine a few years back its pretty simple to swop out I even took the old switch apart cleaned it and put it somewhere safe never to be seen again.
You can get to it and spray some contact cleaner in there if it let's you down.
Post #682223 9th Jan 2024 11:09am
Merchy
For anyone changing the centre mounted ignition switch, mazza7282 posted this excellent 'How to' guide with photos, makes the job quite easy - Thumbs Up
https://www.fullfatrr.com/forum/topic55636...ion+switch
Post #682224 9th Jan 2024 11:25am
