![]() | Home > General (L460 2022) > new electric range rover |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35474 ![]() ![]() |
so, do we think the ' all electric ' range rover will be the ultimate FF? ... - .- -.
i've watched what the tesla cybertruck can do and its really impressive... [0-60 in 2.6 secs]
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3195 ![]() ![]() |
Stan, how are new BEV rangies going to cope with towing a boat/horsebox/tailer? Have just spoken to the Polestar salesman and he admitted that towing will cut the range of a new model 3 from 320 miles real life to less than half. And it only tows 2.2.tonnes. |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
I would have thought improved battery technology, improved charging infrastructure and capability along with the fact that most FF arent driven around with anything attached to the towbar may make them an attractive vehicle assuming they dont go crazy with the price and the insurance is at a sensible level (big ask on that lot |
James, i should imagine the EFF [electic full fat] with it being larger than a polestar will have more room for batteries and therefore will have the pulling power and range..
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2587 ![]() ![]() |
They aren’t: https://www.motortrend.com/reviews/ford-f1...wing-test/ |
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2289 ![]() ![]() ![]() |
These cars are only one side of the plug, what's hardly ever mentioned is the lack of the powergrid. here in Europe powerstations can barely produce enough power to keep up with the current need. France is often importing electricity from Germany, and V.V. It's one of the reasons they install "Linkies" in every household (electricity distribution in control of the power companies) They can see what you are using your electricity for and switch you on or off. Imagine what will happen if the market changes for 30% to electric cars...
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1210 ![]() ![]() ![]() |
Considering how LR have taken their range of cars even higher upmarket, and looking at the cost of the average L460, I would guess that very few of these cars will ever have a tow bar fitted, let alone be actually used.
@merchy
RDR Member Since: 05 Sep 2014 Location: Derbyshire Posts: 278 ![]() ![]() |
I tried towing a mini digger in full EV mode on my l460 managed 35miles before it ran out of juice normal range at that time of year was about 50 miles. Didn't think it was bad and was fun to test, the BEV should be fine towing although I expect overall weight will reduce tow capacity similar to the PHEVs. Range impact will be interesting. MY23 PHEV HSE
Eirik34 Member Since: 16 Dec 2014 Location: Norway Posts: 441 ![]() ![]() |
I think the key question is how LR would manage to place/fit the needed 110+ kWh battery in the MLA flex platform? If they'd used a skateboard platform ala Rivian/EQG etc, it would be easier to fit sufficiently battery capacity in the EV L460. L460 P550e AB SWB MY24
Paul J. Member Since: 13 Jan 2009 Location: Leafy Cheshire Posts: 279 ![]() ![]() |
some more info,
IGP Member Since: 09 Jul 2020 Location: Malvern Posts: 294 ![]() ![]() ![]() |
But, what about when they get older and become less expensive? Unless of course by then they become virtually worthless as all of the batteries need to be replaced. I could not have afforded my L405 when it was new (over £100,000) but at 7 years old it was affordable. And came fitted with a deployable tow bar ![]() I go on holiday in Wiltshire a couple of times a year, and, whilst I could tow my caravan down there in an EV, there are no charging facilities at the site for recharging EV's. So if I plugged it (EV that is) into a normal 240v socket, I would not be able to drive until the next morning at the earliest as it would have used all it's power getting to the site. 2013 Vogue SE SDV8 2013 Freelander 2 SD4 HSE Luxury |
