Home > Maintenance & Mods (L322) > Battery charging via towing port question |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 357 |
First thing is to check you have a 13 pin socket on the back of your car. If yes then pin 9 should be a permanent live and pins 3, 11 and 13 are earths.
21st Nov 2023 12:54pm |
FullfatSteve Member Since: 03 Jan 2023 Location: Bristol Posts: 18 |
Thanks V8 Bob, I will get testing to see what is back there. And then hopefully hunt online to make it up. |
21st Nov 2023 2:10pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
Not available in the shop any longer iirc
21st Nov 2023 2:43pm |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1424 |
No need to be scared of the Gremlins If you fancy a bit of fun DIY with some electrical bits & cable, you can make your own up quite cheaply? I’ve found this website very useful over the years: https://www.12voltplanet.co.uk Also did you search for a how-to on YouTube? Good luck with it! “If it ain’t broke, don’t fix it” -where’s the fun in that? |
21st Nov 2023 4:23pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1374 |
Having bought an adaptor for charging through the towing electrics when the forum shop had them, I can say that they seem to me the most convenient way of connecting to a trickle charger. One can always add a further 'different number of pins' adaptor if the socket and charging adaptor do not match up. Only Range Rovers since 1988 |
21st Nov 2023 6:28pm |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 828 |
https://www.mobilecentre.co.uk/ctek-comfor...ing-socket ______________________________ Simon ______________________________ Range Rover Classic 3.5 efi - Gone Range Rover Classic 3.9 efi - Gone Range Rover Classic 4.2 LSE - Sadly gone Land Rover 110 3.5 - Gone Range Rover P38a 4.0 SE - Pleased it's gone Range Rover P38a 2.5 DHSE - Just sold Range Rover L322 4.4 v8 Petrol - Current |
21st Nov 2023 6:51pm |
Nice. They also do a 13pin one
21st Nov 2023 7:16pm |
Thanks everyone, I decided to take a peek under the dust caps.. think I may have the first to do it in a very long time
21st Nov 2023 8:45pm |
Looking at the link from UK Marine, this looks like it will do the job.. stupid question, as never had a towbar on anything before, I assume I connect it to the white coloured socket , or assume it only connects to 1 of the 7 pin sockets? Guess won’t be long in finding out lol |
21st Nov 2023 8:50pm |
I replaced the old knackered electrics with a lovey new 13 pin one. Looks so much cleaner and simpler etc Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
21st Nov 2023 8:59pm |
It’s the white connector you need to use, same set up as mine.
21st Nov 2023 9:12pm |
https://www.pfjones.co.uk/advice-centre/to...trics.html
21st Nov 2023 9:22pm |
Cheers buddy. Just ordered one and hopefully comes before the old girl doesn’t turn over lol Last edited by FullfatSteve on 21st Nov 2023 9:44pm. Edited 1 time in total |
21st Nov 2023 9:42pm |
Thanks buddy, I’ve ordered one so fingers crossed |
21st Nov 2023 9:44pm |
