![]() | Home > Maintenance & Mods (L405) > Anyone - Cleaning out the drain plugs |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
Strimmer wire/cable works well when ive used it... |
Salsbury Member Since: 19 Jun 2022 Location: Alberta Posts: 105 ![]() ![]() ![]() |
Was this the 405 that was shipped sea freight numerous times? |
ABAB Member Since: 02 Feb 2017 Location: GB Posts: 287 ![]() ![]() ![]() |
Just looking to check my drains by way of preventative maintenance (hopefully).
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1156 ![]() ![]() ![]() |
I would like to know too as I cannot see them either, are they visible when the roof is fully open? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35510 ![]() ![]() |
gino will tell you,
Bloody hell I only want to see where the drain holes are not strip my RR back to its shell. |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1438 ![]() ![]() ![]() |
Yes you can, open the sunroof fully stand on centre console and look down into channel between sunroof and body about 1inch behind line of sunroof when opened, you can pop the trim off and its very visible, you might need a torch depending on light. I wonder actually if you could seal them up and let gravity do the rest when you drive off?
I’ve really struggled to find and test the sunroof drain holes - couldn’t see any photos anywhere online which helped. Plenty of video and photo stuff of rusted away pipes further in the car.
darren3005 Member Since: 01 Nov 2023 Location: Somerset Posts: 66 ![]() ![]() ![]() |
Holey Moley I soo wanted a sliding pano roof when I went looking for my RR. I was a little disapoointed when I went with a fixed one on a vogue but as Gremlin says there's already way to much to worry about without two tiny holes ruining your day |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1276 ![]() ![]() |
To be honest the fixed roof is the best option, I never use the sliding roof anyway. 2018 SE SDV8 4.4 Byron Blue |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1607 ![]() ![]() ![]() |
I’ve not purchased one of these as I don’t have a sunroof, but at the price it seems worth checking out?
