![]() | Home > Technical (L322) > Early L322 light wiper blades |
Googs Member Since: 19 May 2022 Location: Tassie Posts: 158 ![]() ![]() |
Hey SP, I’m in Australia, i found some wiper blades at a car accessory retail outlet….they were full length and i cut them down to size, works a treat
Slow progress Member Since: 30 Jun 2020 Location: Derbyshire Posts: 451 ![]() ![]() |
Thanks for the help. Just found some new old stock ones so went that direction, but given low stock I’ll have no option but to do that next time L322 TD6 2003
I suppose you’re lucky that you found old stock, at least its fixed ! |
For info, headlight washers are only required for mot purposes on vehicles with xenon headlights from September 1 2009 onwards, vehicles manufactured before that date do not need headlight washers whatever the bulbs used. If you have trouble, nothing to stop you removing the headlight washer assemblies completely and fitting blanking plugs to the two holes left. |
322BLL Member Since: 18 Apr 2019 Location: Estonia Posts: 73 ![]() ![]() |
Island used to have them. I replaced mine long time ago but after few months pulled the fuse. They make more arm to the headlight glasses than good. Worst is in winter when the water freezes. So they just keep on rubbing the salt, dirt etc. It will not happen with windscreen wipers but does with headlight ones. |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1544 ![]() ![]() |
G'day Googs. I don't suppose you know the part no. and/or brand for the rubbers, e.g., Tridon, Bosch, etc.? I can go to SuperCrap Auto and have a look. Mine are are as hard as hell. Ron B. VK2OTC 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 798 ![]() ![]() ![]() |
I have changed them many times using a cheap replacement rubber from e-bay. Just cut to length
Thanks Wayne. I thought the blade would need the metal backing strip. Ron B. VK2OTC
use the old 2007 TDV8 VSE
I thought of that but the rubber you linked doesn't have a slot for the strip. Ron B. VK2OTC
Hey Ron, have a look at these mate
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 594 ![]() ![]() ![]() |
This is exactly what I did, too. You can buy a single blade (for a rear windscreen) long enough to give you the required two pieces for the headlamps. PS: I'm always on the lookout for a pair of caps. If anyone has them, please pm me. Thanks |
I tried them but they didn't have the blades unfortunately. I bought some blades from SuperCrap and I am trying to adapt them. Ron B. VK2OTC 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
