Home > Technical (L322) > Early L322 light wiper blades
Slow progress
Can anyone help me, I’m looking to replace the wiper blades for the lights on a 2003 L322, are these identical to the P38 ones? As I’m struggling to find any replacement blades! L322 TD6 2003
Epsom Green- the dogs car which has worked it’s way into being the family car 😮
Post #632700 23rd May 2022 5:21pm
Googs
Australia
Hey SP, I’m in Australia, i found some wiper blades at a car accessory retail outlet….they were full length and i cut them down to size, works a treat
You just need to remember to give one end a slight crimp before you fit them.
Post #633105 28th May 2022 2:26am
Slow progress
Thanks for the help. Just found some new old stock ones so went that direction, but given low stock I’ll have no option but to do that next time L322 TD6 2003
Post #633124 28th May 2022 9:26am
Googs
Australia
I suppose you’re lucky that you found old stock, at least its fixed !
Post #633147 28th May 2022 8:17pm
For info, headlight washers are only required for mot purposes on vehicles with xenon headlights from September 1 2009 onwards, vehicles manufactured before that date do not need headlight washers whatever the bulbs used. If you have trouble, nothing to stop you removing the headlight washer assemblies completely and fitting blanking plugs to the two holes left. Thumbs Up
Post #633149 28th May 2022 8:35pm
322BLL
Estonia
Island used to have them. I replaced mine long time ago but after few months pulled the fuse. They make more arm to the headlight glasses than good. Worst is in winter when the water freezes. So they just keep on rubbing the salt, dirt etc. It will not happen with windscreen wipers but does with headlight ones.
Post #634107 9th Jun 2022 7:26am
p38arover
Australia
G'day Googs. I don't suppose you know the part no. and/or brand for the rubbers, e.g., Tridon, Bosch, etc.? I can go to SuperCrap Auto and have a look.
Mine are are as hard as hell. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #678033 16th Nov 2023 7:16am
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
I have changed them many times using a cheap replacement rubber from e-bay. Just cut to length
https://www.ebay.com.au/itm/385743623447?h...R8rUi_T6Yg 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #678035 16th Nov 2023 8:31am
p38arover
Australia
Thanks Wayne. I thought the blade would need the metal backing strip. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #678036 16th Nov 2023 8:34am
wayneg
use the old 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #678037 16th Nov 2023 8:36am
p38arover
Australia
I thought of that but the rubber you linked doesn't have a slot for the strip. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #678038 16th Nov 2023 8:37am
Googs
Australia
Hey Ron, have a look at these mate
i used these and found them to be good value.
freight is super quick even with Aus Post link below
https://www.wipertech.com.au/wiper-blades/...-1994-2002 2003 RR L322 4.4 ltr Auto Zambezi silver Custom paint
Post #678086 16th Nov 2023 3:43pm
vs322
Greece 2004 Range Rover HSE 4.4 V8 Java Black
This is exactly what I did, too. You can buy a single blade (for a rear windscreen) long enough to give you the required two pieces for the headlamps.
PS: I'm always on the lookout for a pair of caps. If anyone has them, please pm me.
Thanks
Post #679237 1st Dec 2023 4:58pm
p38arover
Australia
I tried them but they didn't have the blades unfortunately.
I bought some blades from SuperCrap and I am trying to adapt them. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #681663 2nd Jan 2024 12:30am
