Home > Technical (L405) > Battery Replacement |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1477 |
Loads of info if you use the Search function on here, (which is why your thread has many readers but no posters) but to make it easy for you, watch this:
16th Nov 2023 11:33am |
Jase71 Member Since: 13 Apr 2016 Location: Mona Vale Posts: 482 |
Thanks Gremlin500. Thats the vid I watched which looks piece of cake. Just couldn't work out if it was just the earlier cars that required the ECU to be updated with the reader? Its the software bit that would force me to take to a garage. thanks 2017 Range Rover Vogue V6 Diesel
16th Nov 2023 11:37am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4303 |
Glenrands can do it for you.
16th Nov 2023 11:38am |
thanks Dr Rob! Duckworths can do the battery delivered for £268.95 and the stealer is quoting £305 2017 Range Rover Vogue V6 Diesel
16th Nov 2023 11:40am |
#1 rule = avoid all main dealers! Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
16th Nov 2023 11:44am |
Agree, I'm so fed up with my local ones. So many screw ups 2017 Range Rover Vogue V6 Diesel
16th Nov 2023 11:45am |
Arch Stanton Member Since: 26 Apr 2012 Location: chavshire Posts: 478 |
my local dealer wanted £1k to replace and code both batteries, a local indy was half that First time FFRR owner |
16th Nov 2023 11:47am |
Hi Jase,
16th Nov 2023 11:50am |
Lots of good independents around here...we are lucky! Glenrands for me all day long though Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
I like your thinking. Its frustrating for someone like me who is an engineer to watch something so simple carried out...usually the car comes back marked as an added bonus 2017 Range Rover Vogue V6 Diesel
16th Nov 2023 11:52am |
Yes, like the idea of them for my next service Dr Rob 2017 Range Rover Vogue V6 Diesel 2006 Range Rover Vogue V8 Diesel - gone |
Hi Jase, update:
16th Nov 2023 12:19pm |
Nasher Member Since: 30 Sep 2009 Location: Down South Posts: 44 |
To return to the original OPs question, is it actually necessary to 'do the ECU bit'.
16th Nov 2023 1:05pm |
RRV8SC Member Since: 02 Oct 2021 Location: SW London Posts: 179 |
What exactly are you “coding” when fitting a new battery? |
16th Nov 2023 1:30pm |
