![]() | Home > Technical (L405) > Battery Replacement |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1685 ![]() ![]() ![]() |
Loads of info if you use the Search function on here, (which is why your thread has many readers but no posters) but to make it easy for you, watch this:
Jase71 Member Since: 13 Apr 2016 Location: Mona Vale Posts: 491 ![]() ![]() ![]() |
Thanks Gremlin500. Thats the vid I watched which looks piece of cake. Just couldn't work out if it was just the earlier cars that required the ECU to be updated with the reader? Its the software bit that would force me to take to a garage. thanks 2017 Range Rover Vogue V6 Diesel
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4334 ![]() ![]() ![]() |
Glenrands can do it for you.
thanks Dr Rob! Duckworths can do the battery delivered for £268.95 and the stealer is quoting £305 |
#1 rule = avoid all main dealers! Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Agree, I'm so fed up with my local ones. So many screw ups 2017 Range Rover Vogue V6 Diesel
Arch Stanton Member Since: 26 Apr 2012 Location: chavshire Posts: 514 ![]() ![]() ![]() |
my local dealer wanted £1k to replace and code both batteries, a local indy was half that First time FFRR owner |
Hi Jase,
Lots of good independents around here...we are lucky! Glenrands for me all day long though ![]() 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
I like your thinking. Its frustrating for someone like me who is an engineer to watch something so simple carried out...usually the car comes back marked as an added bonus |
Yes, like the idea of them for my next service Dr Rob 2017 Range Rover Vogue V6 Diesel 2006 Range Rover Vogue V8 Diesel - gone |
Hi Jase, update:
Nasher Member Since: 30 Sep 2009 Location: Down South Posts: 54 ![]() |
To return to the original OPs question, is it actually necessary to 'do the ECU bit'.
RRV8SC Member Since: 02 Oct 2021 Location: SW London Posts: 185 ![]() ![]() ![]() |
What exactly are you “coding” when fitting a new battery? |
