![]() | Home > Technical (L405) > ... |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 ![]() ![]() ![]() |
Warranty replaced the entire mirror on my last 405 and that mirror used to warm up much quicker than the older existing mirror... As you say above, this one would steam on a crisp cold morning... So I would suggest, time and constant use wear the heater elements out?!?
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1583 ![]() ![]() ![]() |
Could be with most FFRR’s living outdoors due to tiny UK domestic garage dimensions, that inevitable contact corrosion increases resistance and decreases heat? Only guessing, but maybe a strip-down and burnish of contacts/SG200 treatment might improve things? |
I thought the mirrors were live whenever the car was running? Might be worth a meter check and see if they are or weather they are live’d up through the heated rear window circuit? |
Hi Craig, I eventually found this in the WM:
Sorry folks: Please check the online WM for the missing information in bold above, it details the % heat available vs ambient temperature. Unfortunately I was unable to cut & paste from the WM to my post for whatever reason due to website malfunction. “If it ain’t broke, don’t fix it” -where’s the fun in that? |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1153 ![]() ![]() ![]() |
lol, if its cold and wet mine stays in its Garage bed! Sad i know.
Stuart- Member Since: 16 Dec 2017 Location: UK and Hong Kong Posts: 338 ![]() ![]() ![]() |
My L322 used to have steam coming off them. My L405 doesn't, but it only takes a couple of minutes or so to clear them. 2017 4.4 SDV8 Autobiography in black
Ah, a “Garage Queen!” ![]() ![]() ![]() Well, my missus had an Evoque before the fullfat (which did fit in the garage), so rather than get it out of it’s “bed” she frequently just borrowed my truck. Now having the FF on the driveway, her mileage has doubled ![]() ![]() ![]() |
JamboM3 Member Since: 28 Jul 2021 Location: Berkshire Posts: 211 ![]() ![]() ![]() |
Interesting thread. My passenger side no longer heats.
