Home > Technical (L405) > ...
Phoenix
Post #677735 11th Nov 2023 10:07pm
Gremlin500
Yes, very good point, agreed this is a common bugbear with me Censored
Mine are also VERY slow to clear, there’s ZERO information in either the WM or UM on this feature, but it seems the mirror heating is only for “defrost” not “demist”, so only kicks in at very low temperatures, (with the rear screen heater on).
Very frustrating at this time of year when it’s cold/wet or heavy overnight condensation leaving the mirrors useless. (Perhaps lazy yes, but in a £100K+ when new vehicle, one should not have to dither about with warm wash leathers at 6am wiping off mirrors, etc.)
I’d much prefer a manual switch, as on many cars, I’ve had various German cars where the mirrors would literally steam off the water in a minute or two on a cold morning.
As usual, JLR know better than everyone else! Bow down Bow down Bow down Censored Censored Censored
Maybe some enterprising aftermarket supplier will invent “hot” mirrors, to sell by the ten thousand? “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #677738 11th Nov 2023 10:38pm
Warranty replaced the entire mirror on my last 405 and that mirror used to warm up much quicker than the older existing mirror... As you say above, this one would steam on a crisp cold morning... So I would suggest, time and constant use wear the heater elements out?!?
Try looking for new old stock on fleabay?
Post #677740 11th Nov 2023 10:51pm
Gremlin500
Could be with most FFRR’s living outdoors due to tiny UK domestic garage dimensions, that inevitable contact corrosion increases resistance and decreases heat? Only guessing, but maybe a strip-down and burnish of contacts/SG200 treatment might improve things? Question
How to do that? I’m clueless Embarassed “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #677742 11th Nov 2023 11:13pm
I thought the mirrors were live whenever the car was running? Might be worth a meter check and see if they are or weather they are live’d up through the heated rear window circuit?
Post #677744 12th Nov 2023 12:16am
Gremlin500
Hi Craig, I eventually found this in the WM:
EXTERIOR MIRROR HEATING TIMES
On-time Percentage 100% 75% 50% 25% 0% 0%
On vehicles with the parked heating function, exterior mirror heating may also operate when the parked heating function is active, depending on the ambient air temperature.
Ambient Air Temperature in °C (°F)
< -10 (<14> 35 (>95) = 0%
So, above 0 deg C, you lose 25% of heating effect! Trouble is, the the JLR Numptys didn’t realise it takes almost 7x more energy to evaporate water as it does to melt ice! Banging Head Banging Head Banging Head
Schoolboy Physics, for cold damp conditions say from 10C to 0C you stiil need maximum heating!
(Sorry, guys, it took 4 edits due to incomplete forum pasting errors when submitting). Censored EDIT: NOPE! I STILL cannot paste the information I want to here, -chunks missing from the bold bit! WTF! Censored “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #677747 12th Nov 2023 12:47am
Gremlin500
Sorry folks: Please check the online WM for the missing information in bold above, it details the % heat available vs ambient temperature. Unfortunately I was unable to cut & paste from the WM to my post for whatever reason due to website malfunction. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #677750 12th Nov 2023 1:06am
Phoenix
Post #677763 12th Nov 2023 9:43am
caymanblack
lol, if its cold and wet mine stays in its Garage bed! Sad i know.
Poppy signuture is great Phoenix. Thumbs Up overfinch modified
Post #677768 12th Nov 2023 11:43am
Stuart-
My L322 used to have steam coming off them. My L405 doesn't, but it only takes a couple of minutes or so to clear them. 2017 4.4 SDV8 Autobiography in black
2018 D300 SE Velar in champagne
1982 Rolls Royce Silver Spirit in green
Spiffing wheel centre caps, L322 sill repair panels, etc
Post #677840 13th Nov 2023 1:16pm
Gremlin500
Ah, a “Garage Queen!” Rolling with laughter Rolling with laughter Rolling with laughter
Well, my missus had an Evoque before the fullfat (which did fit in the garage), so rather than get it out of it’s “bed” she frequently just borrowed my truck. Now having the FF on the driveway, her mileage has doubled Shocked , but my tank stays full Very Happy Thumbs Up “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #677852 13th Nov 2023 4:19pm
caymanblack
Rolling with laughter yes it's a garage queen for sure. overfinch modified
Post #677855 13th Nov 2023 4:53pm
JamboM3
Interesting thread. My passenger side no longer heats.
I scoured the owners manual online and there is basically no mention of the heated function of the mirrors
Post #677874 13th Nov 2023 7:57pm
Phoenix
Post #677879 13th Nov 2023 8:31pm
Phoenix
Post #679622 6th Dec 2023 4:39pm
