![]() | Home > Technical (L405) > Rear Diff Failure |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1200 ![]() ![]() ![]() |
My Diff is being replaced as I write, it may not be the same as yours as its a AB which has the clutch pack inside, mine is under JLR warranty.
Alex1976 Member Since: 22 Mar 2023 Location: Bucks Posts: 146 ![]() ![]() ![]() |
The rear diff on my 2016 Vogue failed (noisy and leaking oil from the front pinion seal) earlier this year after only 41k miles. Replaced the whole unit under warranty. I think it is a relatively common issue. |
