Home > Technical (L405) > Rear Diff Failure
Petechard
United Kingdom 2015 Range Rover Autobiography TDV6 Fuji White
Rear Diff Failure
Hi, my 405 TDV6 Hybrid is in for service with an Independant - I reported a whining noise thinking it was a wheel bearing but they’ve come back saying the rear diff bearing has failed. There’s no oil loss so looks like a manufacturing defect. Inde suggested there has been a recall on these but I’m struggling to find any evidence of that before a discussion with LR. Can anybody help please?
Post #677435 6th Nov 2023 4:30pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
My Diff is being replaced as I write, it may not be the same as yours as its a AB which has the clutch pack inside, mine is under JLR warranty.
There is a known problem with my type, its been on back order since July. 2017 SDV8 4.4 silicon silver AB
2012 TDV8 4.4 Stornaway Grey AB
2011 TDV8 4.4 Buckingham Blue
2012 VW V6 3.0 Tougreg
Post #677437 6th Nov 2023 5:02pm
Alex1976
United Kingdom 2016 Range Rover Vogue TDV6 Santorini Black
The rear diff on my 2016 Vogue failed (noisy and leaking oil from the front pinion seal) earlier this year after only 41k miles. Replaced the whole unit under warranty. I think it is a relatively common issue.
Post #677494 7th Nov 2023 8:04pm
