![]() | Home > Technical (L322) > Brake Servo - severed non-return valve... |
Looks like another case of age failed plastic parts. AFAIK the valve comes as part of the whole hose assembly as mine is leaking vac overnight and I looked into replacing it. Tricky to get to and you may need a special tool to lever it out of the servo housing.
TDV8_Tommy Member Since: 20 Feb 2019 Location: Pinoso, Valencia Posts: 412 ![]() ![]() ![]() |
Thank you for your help, GayJee.
1997 P38 2.5 DSE auto & 1998 P38 2.5 DT Manual 1988 Vogue 3.5 EFI - Manual, gone. 2004 Volvo C70 2.0T convertible, had since new. 2007 Mazda MX-5 2.0 Sport Roadster/Coupé, had since new. 2024 Mini Cooper S cabrio, JCW kit, 2.0, DCT auto |
The hose is a hard plastic and heat bonded / shrunk to the fittings so likley why it's not a separate part but that doesn't mean you can't find a similar part and connect it to the hose by other means. 2012 TDV8 Vogue (L322) |
There are loads on Ebay/Amazon if you search BMW brake servo check valve /non return valve etc. 2012 TDV8 Vogue (L322) |
The car has been temporarily fixed and a new LR part is on order.
Did you fix it OK? I've just replaced the valve (had to make a tool to extract it) and joined it to the existing pipe with some rubber hose. The old valve shows a slow leak when on my 'Milty vac' but will know for sure when I start it up on Monday. 2012 TDV8 Vogue (L322) |
We did a temporary fix, a plastic pipe bridge between the pipe and valve. A double male fitting, I think water irrigation piping!
Heathy Member Since: 19 Feb 2017 Location: Marks Tey, Essex Posts: 53 ![]() ![]() ![]() |
I did this a couple of weeks ago
I'm still loosing vacuum out of the servo when parked for more than a day so it wasn't the valve even though it was leaking. I can live with it though. 2012 TDV8 Vogue (L322) |
mxpUz6Q Member Since: 19 Sep 2022 Location: here Posts: 12 ![]() |
Hi,
