Home > Technical (L322) > Brake Servo - severed non-return valve... |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3241 |
Looks like another case of age failed plastic parts. AFAIK the valve comes as part of the whole hose assembly as mine is leaking vac overnight and I looked into replacing it. Tricky to get to and you may need a special tool to lever it out of the servo housing.
6th Sep 2023 4:40pm |
TDV8_Tommy Member Since: 20 Feb 2019 Location: Pinoso, Valencia Posts: 398 |
Thank you for your help, GayJee.
6th Sep 2023 4:55pm |
The hose is a hard plastic and heat bonded / shrunk to the fittings so likley why it's not a separate part but that doesn't mean you can't find a similar part and connect it to the hose by other means. 2012 TDV8 Vogue (L322) |
6th Sep 2023 5:13pm |
There are loads on Ebay/Amazon if you search BMW brake servo check valve /non return valve etc. 2012 TDV8 Vogue (L322) |
6th Sep 2023 5:33pm |
The car has been temporarily fixed and a new LR part is on order.
7th Sep 2023 11:07am |
Did you fix it OK? I've just replaced the valve (had to make a tool to extract it) and joined it to the existing pipe with some rubber hose. The old valve shows a slow leak when on my 'Milty vac' but will know for sure when I start it up on Monday. 2012 TDV8 Vogue (L322) |
22nd Sep 2023 4:32pm |
We did a temporary fix, a plastic pipe bridge between the pipe and valve. A double male fitting, I think water irrigation piping!
22nd Sep 2023 5:24pm |
Heathy Member Since: 19 Feb 2017 Location: Marks Tey, Essex Posts: 53 |
I did this a couple of weeks ago
4th Nov 2023 5:40pm |
I'm still loosing vacuum out of the servo when parked for more than a day so it wasn't the valve even though it was leaking. I can live with it though. 2012 TDV8 Vogue (L322) |
4th Nov 2023 7:25pm |
mxpUz6Q Member Since: 19 Sep 2022 Location: here Posts: 12 |
Hi,
25th Oct 2024 7:12pm |
