![]() | Home > Maintenance & Mods (L322) > Coolant loss |
Could be leaking from a number of places. If it's still under warranty just take it back to the dealer to sort out. 2012 TDV8 Vogue (L322) |
Jaysto Member Since: 23 Oct 2023 Location: Liverpool Posts: 13 ![]() ![]() ![]() |
Thanks ,it’s one of the warranty type where they don’t like to pay out .
No type of warranty will cover this as they will deem it to be wear and tear on a car this age. Get it to a specialist for a proper diagnosis. 2012 TDV8 Vogue (L322) |
Wondering if it is the oil cooler,would the warranty cover it |
Good luck with that........ 2012 TDV8 Vogue (L322) |
Fullfatfan Member Since: 17 Mar 2023 Location: Sheffield Posts: 6 ![]() ![]() |
Sounds pretty similar to what mine is doing,I’m booked in next week to have oil cooler checked as they apparently prone to leak in later years, there’s a pipe goes into rear of cooler which has a couple of little O rings that deteriorate over the years as does the internal rubber gasket inside the cooler it’s self, I only noticed the fault last week upon returning home from work ,I could smell the burning coolant ,as my drive is on an uphill slope I can only presume the leak fills the area cooler is in between the V and runs over the rear and onto bell housing hence the smell ??
