Home > Technical (L322) > Coolant appears low but no warnings |
KF Member Since: 19 Jul 2022 Location: Kerava Posts: 43 |
There probably is an issue with coolant disappearing and the sensor has been disabled, ask me how I know -07 Stornoway Gray TDV8 |
1st Nov 2023 5:37pm |
camcc Member Since: 01 Oct 2023 Location: Godalming, Surrey Posts: 34 |
Oh dear, how can I check if the sensor has been disabled? I have an IID tool. |
1st Nov 2023 6:19pm |
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 526 |
It may need to be lower to trigger the warning. I lost coolant the other week, and stopped as soon as the message came on, but it did look like the level was lower than that.
1st Nov 2023 6:24pm |
With IID tool you can able/disable that, can´t really member the route to find it, but it´s in the CCF. Just wonder around and you will find it. -07 Stornoway Gray TDV8 |
1st Nov 2023 8:12pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4308 |
Give them a call and I’m sure Ross will want to take a look for you Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
1st Nov 2023 8:20pm |
fanders Member Since: 10 Jul 2013 Location: Hants, UK Posts: 318 |
Undo the expansion tank bleed screw and take off the bottle cap, and watch the level rise in the bottle. If it settles between the fill lines, all is well.
1st Nov 2023 9:19pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 |
If your level sensor is faulty, it is likely to throw up the error on your dashboard anyway. The level sensor is quite low down in the tank, because that's exactly what the tank is - an expansion tank.
3rd Nov 2023 1:30am |
Thanks all for your responses!
3rd Nov 2023 10:30am |
All normal to me
3rd Nov 2023 10:31am |
Yep, 4.4 AJV8! |
3rd Nov 2023 10:42am |
