![]() | Home > Technical (L322) > Coolant appears low but no warnings |
KF Member Since: 19 Jul 2022 Location: Kerava Posts: 43 ![]() ![]() ![]() |
There probably is an issue with coolant disappearing and the sensor has been disabled, ask me how I know |
camcc Member Since: 01 Oct 2023 Location: Godalming, Surrey Posts: 38 ![]() ![]() |
Oh dear, how can I check if the sensor has been disabled? I have an IID tool. |
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 526 ![]() ![]() ![]() |
It may need to be lower to trigger the warning. I lost coolant the other week, and stopped as soon as the message came on, but it did look like the level was lower than that.
With IID tool you can able/disable that, can´t really member the route to find it, but it´s in the CCF. Just wonder around and you will find it. -07 Stornoway Gray TDV8 |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4323 ![]() ![]() ![]() |
Give them a call and I’m sure Ross will want to take a look for you |
fanders Member Since: 10 Jul 2013 Location: Hants, UK Posts: 318 ![]() ![]() ![]() |
Undo the expansion tank bleed screw and take off the bottle cap, and watch the level rise in the bottle. If it settles between the fill lines, all is well.
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
If your level sensor is faulty, it is likely to throw up the error on your dashboard anyway. The level sensor is quite low down in the tank, because that's exactly what the tank is - an expansion tank.
Thanks all for your responses!
All normal to me |
Yep, 4.4 AJV8! |
