Home > Maintenance & Mods (L322) > TDV8 Oil, is C2 acceptable?
TDV8_Tommy
Spain 2012 Range Rover Westminster TDV8 Baltic Blue
Asking for a friend, who is going around the houses for oil for his ´12 4.4 TDV8.
We know the correct spec, per the owner's manual, it states ACEA C1 (I assume for ash and the DPF) the local motor factor says ACEA C2 is better and okay...I´m not sure, personally, I only use the absolute correct spec.
Any ideas welcome.
Thanks,
Tom 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
1997 P38 2.5 DSE auto & 1998 P38 2.5 DT Manual
1988 Vogue 3.5 EFI - Manual, gone.
2004 Volvo C70 2.0T convertible, had since new.
2007 Mazda MX-5 2.0 Sport Roadster/Coupé, had since new.
2024 Mini Cooper S cabrio, JCW kit, 2.0, DCT auto
Post #675644 16th Oct 2023 3:43pm
DrRob
Use correct spec. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #675646 16th Oct 2023 3:51pm
JayGee
C2 can be used if you can't get C1 and it's better than old oil contaminated with soot and diesel. While C1 is classed as 'low ash' that doesn't mean no ash and on an old DPF on a car with a lot of miles it's likley not a big issue esp if you get some C1 next service. Most important thing is the correct viscosity rating. 2012 TDV8 Vogue (L322)
Post #675651 16th Oct 2023 4:45pm
TDV8_Tommy
Agree with all of the above, thank you.
If it were me, and like I always do, I’d use the correct spec oil. But this is on behalf of a mate who’s bagged a 2012 Westie. Two Westies in our small local Spanish town tickles me.
Getting correct spec oil here takes ages and the choice is very limited so I thought it was at least worth an ask regarding the C1, obviously, viscosity is non-negotiable. 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
Post #675673 16th Oct 2023 7:21pm
Mikey
C2 is still a low ash oil, but not as low as C1
Can't see it causing any issues for short term use though
Post #675679 16th Oct 2023 8:25pm
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Does your car have a DPF, also have a full read of the handbook if its a Spanish delivered and spec car. My 2007 3.6 Australian spec says 10w40 for hot climates. Australian 4.4`s don't have DPF`s. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #675695 17th Oct 2023 4:54am
TDV8_Tommy
The query is for a friend, but we have the same, 4.4 TDV8 with DPF and EGR originally a UK car. 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
Post #675718 17th Oct 2023 10:51am
