Home > Maintenance & Mods (L322) > suspension issue |
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 456 |
Right managed to get car to raise and lower still getting the error can’t calibrate the suspension and now in the 4x4 screen all of the wheels have the red tags flashing under the wheels |
5th Oct 2023 2:58pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35465 |
pretty sure you can reset to original settings [before you played with them] ... - .- -.
5th Oct 2023 3:30pm |
Is that in the height adjust menu .? |
5th Oct 2023 3:33pm |
tried to reset to default it starts to update but then fails on get error e 0 |
6th Oct 2023 12:05pm |
ok have tried hard reset ...........still the same fault .i have been through all of the rlm calibration setting you name it i have tried them all nothing as soon as i try to raise or lower the suspension get bong and suspension fault .im at a loss |
12th Oct 2023 1:12pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
What is the 4x4i screen showing? all wheels at the same height? any flashing red cursors? What DTC is set after attempting calibration?
12th Oct 2023 1:27pm |
right screen shows all bottom marker’s flashing red , if i try to raise car i get error and says standered height (but it’s. it moved) if i lower car error and then shows access height ……it does try to raise and lower but then just stops and errors….whats so frustrating it that it was all working fine up to the point i went to calibrate suspension…..wife not happy with me |
12th Oct 2023 1:47pm |
Let's take a step back - why did you decide/need to recalibrate the suspension height?
12th Oct 2023 2:42pm |
i was thinking of maybe disconnecting the air suspension control module (if i can find it ) and see what error codes pop up ???? |
12th Oct 2023 2:43pm |
i have replaced one of the rear airbags and one of the front height sensors ,and when i measured each corner the other week they where all different but couldn't do anything about it till now as i didn't have a gap tool |
12th Oct 2023 2:45pm |
The rear airbag shouldn't have made a difference as it's the height sensors that measure the height, the airflow to & from the airbag is as a result of the measurement, not the other way around.
12th Oct 2023 2:49pm |
ok understand ref the air bag i took the measurements from the middle of the wheel to the top of the wheel arch sorry don't have the piece of paper with the measurement's on (it was last week i tried) .what i can tell you is that if i can get into guided calibration ...
12th Oct 2023 3:01pm |
They may be too far out to allow a successful calibration - you might need to adjust some values so they're all a bit closer together to get a calibration file to build (Autologic & IDS can do it 'as factory')
12th Oct 2023 3:19pm |
phoenix....appreciate the help. those heights you have said ring a bell and im sure my measurement's where between 30-40 mm different just going to search for "(from GAP IIRC) telling you how to manipulate the measurements" |
12th Oct 2023 5:58pm |
