Home > Maintenance & Mods (L322) > suspension issue
will308f
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
suspension issue
hi guys
went to do a suspension calibration using gap tool it wouldn't do it and now have error code C1A00-54 Control module ???........has been working fine till i went and tried to calibrate, never had this before .any help to point me in the right direction to clear it would be much appreciated Thumbs Up
Post #674884 4th Oct 2023 3:14pm
will308f
Right managed to get car to raise and lower still getting the error can’t calibrate the suspension and now in the 4x4 screen all of the wheels have the red tags flashing under the wheels Big Cry Big Cry
Post #674947 5th Oct 2023 2:58pm
pretty sure you can reset to original settings [before you played with them] ... - .- -.
Post #674951 5th Oct 2023 3:30pm
will308f
Is that in the height adjust menu .?
Post #674952 5th Oct 2023 3:33pm
will308f
tried to reset to default it starts to update but then fails on get error e 0 Big Cry Big Cry Big Cry
Post #674995 6th Oct 2023 12:05pm
will308f
ok have tried hard reset ...........still the same fault .i have been through all of the rlm calibration setting you name it i have tried them all nothing as soon as i try to raise or lower the suspension get bong and suspension fault .im at a loss Censored Censored Censored Censored Censored Sad Sad Sad
Post #675395 12th Oct 2023 1:12pm
Phoenix
What is the 4x4i screen showing? all wheels at the same height? any flashing red cursors? What DTC is set after attempting calibration?
TBH you may well need someone with Autologic / IDS to rebuild the initial calibration, not difficult but seemingly a 'gap' in the abilities of Gap IID?
Post #675400 12th Oct 2023 1:27pm
will308f
right screen shows all bottom marker’s flashing red , if i try to raise car i get error and says standered height (but it’s. it moved) if i lower car error and then shows access height ……it does try to raise and lower but then just stops and errors….whats so frustrating it that it was all working fine up to the point i went to calibrate suspension…..wife not happy with me Laughing Laughing Laughing Laughing
Post #675408 12th Oct 2023 1:47pm
Phoenix
Let's take a step back - why did you decide/need to recalibrate the suspension height?
It sounds like it's sending air in but seeing no change (or reaching the calibrated maximum/minimum allowable height) then aborting the change.
What measurements did you input?
Post #675413 12th Oct 2023 2:42pm
will308f
i was thinking of maybe disconnecting the air suspension control module (if i can find it ) and see what error codes pop up ????
Post #675414 12th Oct 2023 2:43pm
will308f
i have replaced one of the rear airbags and one of the front height sensors ,and when i measured each corner the other week they where all different but couldn't do anything about it till now as i didn't have a gap tool
Post #675416 12th Oct 2023 2:45pm
Phoenix
The rear airbag shouldn't have made a difference as it's the height sensors that measure the height, the airflow to & from the airbag is as a result of the measurement, not the other way around.
The height sensor on the front will obviously have a bearing on the measurement, how are you measuring and what figures did you input?
Post #675417 12th Oct 2023 2:49pm
will308f
ok understand ref the air bag Thumbs Up i took the measurements from the middle of the wheel to the top of the wheel arch sorry don't have the piece of paper with the measurement's on (it was last week i tried) .what i can tell you is that if i can get into guided calibration ...
front left 182
front right 175
rear left 224
rear right 200
im also in contact with gap as i get an error code e0 or e1
Post #675418 12th Oct 2023 3:01pm
Phoenix
They may be too far out to allow a successful calibration - you might need to adjust some values so they're all a bit closer together to get a calibration file to build (Autologic & IDS can do it 'as factory')
There is a file on here somewhere (from GAP IIRC) telling you how to manipulate the measurements but as a start, try:-
FL 182
FR 178
RL 214
RR 198
ETA_ just looking at those measurements - they're way off. The heights from centre of the wheel to wheelarch should be in the 480-490mm range, it's probably refusing to calibrate as the measurements are out of range.
Post #675420 12th Oct 2023 3:19pm
will308f
phoenix....appreciate the help. those heights you have said ring a bell and im sure my measurement's where between 30-40 mm different just going to search for "(from GAP IIRC) telling you how to manipulate the measurements"
Post #675438 12th Oct 2023 5:58pm
