Home > General (L405) > L405 Arm Rests are useless...
JDGeorgia
United States 2006 Range Rover HSE 4.4 V8 Buckingham Blue
Totally a 1st world problem, I get it. But the arm rests on my 2016 L405 TD6 cannot be adjusted above the center console height. Is it just mine?!?!?
In my '06 L322, I can adjust them upward about 10-15Deg. On long drives the changing position helps keep things from getting 'stove up'. I crank the arm rests up as high as it will go and it is about even with the center console. With the smaller feeling cabin, I don't really need them, but it would be nice to regain that adjustability.
Anyone else have an opinion? 2006 L322 HSE LUX 4.4NA Jag V8 Buckingham Blue/Ivory - 'Col Reb'
Rolled Yahtzee Aug 2023 222,222Miles
2016 L405 HSE TD6. Santorini Black over Almond. - 'Donna the Diesel'
Only L405 IN THE KNOWN UNIVERSE with an L494 Shift Lever Fitted!
97K at purchase Sept of 2023
Post #675360 11th Oct 2023 9:20pm
i havent used mine in any of the FF's I've owned... ... - .- -.
Post #675367 12th Oct 2023 6:38am
j_rov
I noticed that too in my new one. I thought it was a fault to be honest as you may as well use the cubby box than the armrest. __
2018 L405 3.0 TDV6 Vogue SE Fuji White
2000 4.6 V8 HSE Oxford Blue
1994 3.9 V8 Vogue Ardennes Green - resto project
Land Rover History:
2010 3.6 TDV8 Autobiography Stornoway Grey
2001 Discovery 2 TD5 GS
1999 Discovery 2 V8i XS
1994 Discovery 300Tdi
1993 Discovery 200Tdi
1989 Range Rover Vogue SE 3.5EFi
1976 Series 3 2.25
1977 Range Rover 2 door 3.5 Carb
Post #675370 12th Oct 2023 7:27am
James W
Saudi Arabia 2017 Range Rover Autobiography SDV8 Siberian Silver
Hmm. I find mine quite comfy to be honest and always flip it down as I'm driving off out of habit. But I do like quite a high diriving postion (I have my seat base quite high and raised) so maybe mine feel a lot higher than the cubby box because of that. If I lean on the cubby box, I would be leaning down to the left (in the UK Laughing ) FFRR SDV8 Autobiography
Post #675371 12th Oct 2023 7:47am
j_rov
maybe that's the key then!
I'm tall so seat is not raised much. I also have a fairly straight back to the chair so that would affect the arm rest stop i guess.
My p38 allows far more adjustment though! __
Land Rover History:
1976 Series 3 2.25
Post #675372 12th Oct 2023 7:50am
Vogue
No problem with mine and use them every journey 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #675390 12th Oct 2023 12:19pm
supershuttle
Mine is OK, the only problem I encounter is that it seems to need winding up every time I drive but as I say other than that its fine. Geoff
Post #675392 12th Oct 2023 12:24pm
ChrisJC
United Kingdom 2014 Range Rover Vogue SDV8 Aintree Green
I can't get on with mine. They have a rounded top, so my elbow falls down one side or the other! The P38 ones were wide and flat topped, and worked very well.
I am considering 3D printing something that clips on to rest my elbow on.
Chris. L405 - 4.4SDV8 Vogue
P38 - 4.6V8 HSE
Land Rover series IIA V8
Post #675435 12th Oct 2023 5:32pm
