![]() | Home > General (L405) > L405 Arm Rests are useless... |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35463 ![]() ![]() |
i havent used mine in any of the FF's I've owned... ... - .- -.
j_rov Member Since: 10 Jan 2017 Location: Warwickshire Posts: 386 ![]() ![]() |
I noticed that too in my new one. I thought it was a fault to be honest as you may as well use the cubby box than the armrest. __
James W Member Since: 29 Nov 2009 Location: Riyadh Posts: 294 ![]() ![]() ![]() |
Hmm. I find mine quite comfy to be honest and always flip it down as I'm driving off out of habit. But I do like quite a high diriving postion (I have my seat base quite high and raised) so maybe mine feel a lot higher than the cubby box because of that. If I lean on the cubby box, I would be leaning down to the left (in the UK |
maybe that's the key then!
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3754 ![]() ![]() |
No problem with mine and use them every journey 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3852 ![]() ![]() ![]() |
Mine is OK, the only problem I encounter is that it seems to need winding up every time I drive but as I say other than that its fine. Geoff |
ChrisJC Member Since: 14 Sep 2023 Location: Northants Posts: 132 ![]() ![]() ![]() |
I can't get on with mine. They have a rounded top, so my elbow falls down one side or the other! The P38 ones were wide and flat topped, and worked very well.
