![]() | Home > Maintenance & Mods (L322) > L322 " air suspension Slow to Rise" |
If the compressor is running for long periods l would be inclined to check the air bags for potential leaks particularly in the highest setting. The compressor shouldn’t run very much at all. |
Merlin Member Since: 19 Nov 2020 Location: Scarborough Posts: 16 ![]() ![]() |
Thanks for the reply, the air bags are good no leaks.
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 605 ![]() ![]() ![]() |
Have you checked air tank ? might have a small hole in it? |
Super Sloth Member Since: 23 Jun 2020 Location: Derbyshire Posts: 25 ![]() ![]() |
Internal leak on the compressor is another possibility. |
Hi guys
AFAIK you can swop between them using the GAP IID tool. Also look at reconditioned ones? 2012 TDV8 Vogue (L322) |
Ok don't know what afaik means, and do you know who does the reconditioned ones?
Sussed the afaik bit |
Are you sure it’s the compressor rather than a bag or line with a weep?
JDGeorgia Member Since: 11 Oct 2023 Location: Atlanta GA Posts: 159 ![]() ![]() ![]() |
This happened to me years ago on my 2006 4.4NA HSE Lux - it ran all the time because the internals were tired. Let's say that a normal piston stroke is 5 CC... I was maybe getting 2 CC per stroke because the rest was blowing past the worn nylon ring. I rebuilt it with a kit - that lasted maybe another 3 or 4 years and I ended up just replacing it. It was done at an Indie shop... so I am not sure what model I have now. That was 3 or 4 years ago and no issues. It is pricey - but if you are going to keep the truck, it is worth it. |
DanRRL322sc Member Since: 16 May 2022 Location: Bedfordshire Posts: 55 ![]() ![]() |
My 2007 4.2 SC suffered the same slow to rise messages. It turned out to be a pin hole in one of the air bags and a worn out Hitachi pump.
