![]() | Home > Technical (L405) > I'm now a Regeneration trainee nerd--lol |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1593 ![]() ![]() ![]() |
I just have mine both set at value 1, red below one, and green above one.
James W Member Since: 29 Nov 2009 Location: Riyadh Posts: 294 ![]() ![]() ![]() |
Super, have added some more formatting. Need to go and try it for real later (not just demo mode) and see if my Bluetooth OBD dongle works okay with it
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1265 ![]() ![]() |
No --just set the top threshold to 1, the actual value will show 0 when all is OK- Regen not happening, no alarm, it will show 1 passive Regen when the exhaust temp is greater than 250C ish value no alarm. When it changes to 2 then you get visual and/or sound alarm. See below copy of mine for visual, Ignore the red 13 screen print was done in Demo mode, the only numbers you will see here will be 0,1 or 2
Sound (again ignore the red 24 demo mode)
Right just had a first go at this for real, had to pop to my folks house which is about 15 mins of suburban/rural driving, pretty continuous, min 30 max 60 mph.
JamesW
#2 Get the “Pro” version, the free version is a dead loss. |
Bought the Pro version - just hadn't got around to it previously. Can't find the Units field for Sensor Properties yet but it's no great issue at the moment. Looking forward to seeing what happens tomorrow on a longer motorway journey |
Ah! Another regeneration trainee nerd is born! |
TonyHammer61 Member Since: 14 Sep 2023 Location: Sidcup, Kent Posts: 11 ![]() ![]() ![]() |
Hi Kot
“If it ain’t broke, don’t fix it” -where’s the fun in that? |
Amazon says that this does NOT fit a Land Rover Range Rover IV SUV 4.4 Sdv8 4X4
I use the wifi vgate search Amazon for Vgate iCar Pro Wi-Fi OBD2 OBDII Car Auto Diagnostic Scanner Tool Check Engine Light for iOS i-Phone/iPad/Android Compatible With Adapter. But has Gremlin says you can get the same vgate which is Bluetooth both do the job and the iOS car scanner app is https://apps.apple.com/gb/app/car-scanner-elm-obd2/id1259933623 but get the pro version (in app purchases) 2018 SE SDV8 4.4 Byron Blue |
I would say Amazon are wrong, any OBD2 device will fit any modern car. 2018 SE SDV8 4.4 Byron Blue |
