![]() | Home > Maintenance & Mods (L322) > Tatty plastics refinish. |
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 596 ![]() ![]() ![]() |
After getting the serious stuff out of the way, I'm now in a position to play around with those minor niggles that let the car aesthetics down.
Wouldn't it be easier just to remove it with a blade and paint it off the car? 2012 TDV8 Vogue (L322) |
I thought about it but it's glued and therefore runs the risk of bending out of shape. |
You are correct. I just didn't have the guts to do that. I always tend to avoid anything even remotely likely to open another can of worms...which tends to happen more often than not with our cars |
Next up, from the bottom of the bucket list this time, come the headlamp wipers.
And closing the day with the rear seat latch trims. Looked horrible and were the first ones I noticed when I bought the car. Middle one is unaffected so I assume this is UV damage.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8546 ![]() ![]() ![]() |
Top job, makes a big difference... |
Thanks Pete! I'll make sure to ask my local paint shop about the adhesion promoter. I have a long list of plastics to be done actually. |
It's well worth using it, it's like spraying water so easy to get runs, a few light coats is best, I've found using the minimum amount of paint on plastic improves it's longevity.......
Good info right there, Pete |
Mine was split so I covered it in vinyl and then colour matched it with leather paint....
I have a crack or two on the driver's side but not as bad as yours. I'm pretty confident I can get it epoxy glued, then sanded and painted over. There's also a spot where the metal trim has peeled but it's not cut or cracked. I think I can slide a tiny amount of glue underneath and stick it back on properly.
There's a VW plastics adhesion promoter in a spray can, works very well as a paint prep and as a cleaner/tack spray for repairing broken bits with epoxy etc. I'll dig out the part number on Monday. |
The seat side trim is that waxed plastic, the epoxy I tried would not glue it well. melting it with a soldering iron works but paint didn't want to stick to it well either....
