Home > Maintenance & Mods (L322) > Tatty plastics refinish. |
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 584 |
After getting the serious stuff out of the way, I'm now in a position to play around with those minor niggles that let the car aesthetics down.
2nd Sep 2023 8:57am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3200 |
Wouldn't it be easier just to remove it with a blade and paint it off the car? 2012 TDV8 Vogue (L322) |
2nd Sep 2023 9:07am |
I thought about it but it's glued and therefore runs the risk of bending out of shape. |
2nd Sep 2023 9:09am |
You are correct. I just didn't have the guts to do that. I always tend to avoid anything even remotely likely to open another can of worms...which tends to happen more often than not with our cars |
2nd Sep 2023 9:20am |
Next up, from the bottom of the bucket list this time, come the headlamp wipers.
2nd Sep 2023 5:06pm |
And closing the day with the rear seat latch trims. Looked horrible and were the first ones I noticed when I bought the car. Middle one is unaffected so I assume this is UV damage.
2nd Sep 2023 5:21pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
Top job, makes a big difference...
2nd Sep 2023 7:38pm |
Thanks Pete! I'll make sure to ask my local paint shop about the adhesion promoter. I have a long list of plastics to be done actually. |
2nd Sep 2023 7:42pm |
It's well worth using it, it's like spraying water so easy to get runs, a few light coats is best, I've found using the minimum amount of paint on plastic improves it's longevity.......
2nd Sep 2023 7:50pm |
Good info right there, Pete And I know just where this is going to be needed the most.
2nd Sep 2023 7:54pm |
Mine was split so I covered it in vinyl and then colour matched it with leather paint....
2nd Sep 2023 8:17pm |
I have a crack or two on the driver's side but not as bad as yours. I'm pretty confident I can get it epoxy glued, then sanded and painted over. There's also a spot where the metal trim has peeled but it's not cut or cracked. I think I can slide a tiny amount of glue underneath and stick it back on properly.
2nd Sep 2023 8:23pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
There's a VW plastics adhesion promoter in a spray can, works very well as a paint prep and as a cleaner/tack spray for repairing broken bits with epoxy etc. I'll dig out the part number on Monday. |
2nd Sep 2023 8:58pm |
The seat side trim is that waxed plastic, the epoxy I tried would not glue it well. melting it with a soldering iron works but paint didn't want to stick to it well either....
2nd Sep 2023 9:06pm |
