Home > Maintenance & Mods (L322) > Tatty plastics refinish.
Page 1 of 3 123>
vs322
Greece 2004 Range Rover HSE 4.4 V8 Java Black
After getting the serious stuff out of the way, I'm now in a position to play around with those minor niggles that let the car aesthetics down.
First of all, got myself a couple rattle cans of Land Rover LBO aka Brunel Grey or Brunel Chrome. I ordered them from my local paint store and had them within a week.
I also got a 250ml can of Java Black although I'm only going to use drops for some stone chips.
First one was the boot lid horizontal strip:
Absolutely atrocious and chipped
Some wrapping and masking, that was the only difficult part.
(Notice the...Marxist detail on the paper Laughing )
After some sanding and not less than eight coatings...
Looks factory fresh from a few meters away!
Almost perfect up close
I will update this thread with further progress.
Post #672538 2nd Sep 2023 8:57am
JayGee
Wouldn't it be easier just to remove it with a blade and paint it off the car? 2012 TDV8 Vogue (L322)
Post #672542 2nd Sep 2023 9:07am
vs322
I thought about it but it's glued and therefore runs the risk of bending out of shape.
Post #672543 2nd Sep 2023 9:09am
JayGee
You can run a thin knife under it from the bottom. Clean off the mastic with brake cleaner/ lighter fluid and re attach with double sided trim tape. 2012 TDV8 Vogue (L322)
Post #672544 2nd Sep 2023 9:16am
vs322
You are correct. I just didn't have the guts to do that. I always tend to avoid anything even remotely likely to open another can of worms...which tends to happen more often than not with our cars Whistle
Post #672547 2nd Sep 2023 9:20am
vs322
Next up, from the bottom of the bucket list this time, come the headlamp wipers.
Decided to do them in situ. The caps aren't in their best shape but everything works and as I already had a pair stolen, I have them glued on. I might replace the whole assemblies if and when the right ones show up.
Notice the white tac on the water sprayer nozzle.
Post #672564 2nd Sep 2023 5:06pm
vs322
And closing the day with the rear seat latch trims. Looked horrible and were the first ones I noticed when I bought the car. Middle one is unaffected so I assume this is UV damage.
Paint peels off by the fingernails. Some wet sanding with P600 helps break down the layer and speed up the process. Can't afford to have any spot left as the coating is readily detached. Didn't bother to do the undersides though. Not visible and besides I wouldn't want any fresh paint in touch with the upholstery
One last spray blast and done. Will let them dry overnight...
Very pleased with the result.
Post #672565 2nd Sep 2023 5:21pm
Top job, makes a big difference... Bow down
If you do any more plastic parts then get an aerosol of Plastic Adhesion Promoter, it's a clear product that you spray on plastic and it helps the paint stay on longer.... Thumbs Up Pete
Post #672572 2nd Sep 2023 7:38pm
vs322
Thanks Pete! I'll make sure to ask my local paint shop about the adhesion promoter. I have a long list of plastics to be done actually.
Post #672574 2nd Sep 2023 7:42pm
It's well worth using it, it's like spraying water so easy to get runs, a few light coats is best, I've found using the minimum amount of paint on plastic improves it's longevity.......
If your door handles need doing then there are some tips here....
https://www.fullfatrr.com/forum/topic27260.html
Have fun... Thumbs Up Pete
Post #672578 2nd Sep 2023 7:50pm
vs322
Good info right there, Pete Thumbs Up And I know just where this is going to be needed the most.
And YES!
Was thinking of taking on the door handles tomorrow Cool
I've bookmarked your inspirational thread quite a while ago Bow down
Post #672579 2nd Sep 2023 7:54pm
Mine was split so I covered it in vinyl and then colour matched it with leather paint....
About a 3rd of the way down this page.... Thumbs Up
https://www.fullfatrr.com/forum/topic24082-165.html Pete
Post #672583 2nd Sep 2023 8:17pm
vs322
I have a crack or two on the driver's side but not as bad as yours. I'm pretty confident I can get it epoxy glued, then sanded and painted over. There's also a spot where the metal trim has peeled but it's not cut or cracked. I think I can slide a tiny amount of glue underneath and stick it back on properly.
I considered having both sides vinyl wrapped or even leather wrapped but no one here is willing to take on the challenge for love nor money...
Post #672585 2nd Sep 2023 8:23pm
Phoenix
There's a VW plastics adhesion promoter in a spray can, works very well as a paint prep and as a cleaner/tack spray for repairing broken bits with epoxy etc. I'll dig out the part number on Monday.
Post #672589 2nd Sep 2023 8:58pm
The seat side trim is that waxed plastic, the epoxy I tried would not glue it well. melting it with a soldering iron works but paint didn't want to stick to it well either....
It was pretty easy to cover it with vinyl, contact adhesive on both sides then lay it over the top and start to stretch around the edges, with leather it would be much harder.... Thumbs Up Pete
Post #672590 2nd Sep 2023 9:06pm
Page 1 of 3 123>
