Home > Technical (L322) > no heater blower |
Matisse Member Since: 02 May 2021 Location: Massachusetts Posts: 4 |
So I’ve got an 08. Not quite as big a hole as the 09, but I can copy that shape and trim.
2nd May 2021 10:46pm |
benjwom Member Since: 13 Apr 2017 Location: Sheffield Posts: 12 |
Really regret selling my old L322 so thought it would be a good idea to buy another one. Less than a week into ownership the heater blower started making a noise so after much faffing about trying to get the clam shell like baffles to stay open with the fan off so I could check it for debris through the filter housing, it seems the fan is starting to die. Thought I would be better to change it before it gets worse and starts taking fuses out with it, and how hard can it be to change a heater fan?
16th May 2023 8:34am |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1464 |
So, I have joined the club and replaced my blower with no cutting at all (although some cutting is needed on vehicles pre 2009).
3rd Aug 2023 1:39pm |
Epson Green Member Since: 20 Mar 2021 Location: Sutton Coldfield Posts: 110 |
Hi Gary
4th Aug 2023 11:33am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
Looking forward to seeing the write up Gary! Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
4th Aug 2023 11:35am |
Gary, remind me of the symptoms you were getting please 🙏 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
4th Aug 2023 2:12pm |
Squeaking (like there was a family of mice) when the fan was running, especially when just starting the car for the day. It was more prominent at temperatures below 10 degrees. 2015 Range Rover Autobiography 4.4 SDV8 |
4th Aug 2023 3:16pm |
Some photos from the job:
4th Aug 2023 6:50pm |
Looking forward to seeing the full write up on both jobs now 😀 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
5th Aug 2023 5:23am |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1523 |
I'm doing my 2003 Vogue now.
1st Jan 2024 6:44am |
What is that foam bulge for? It's very dense foam. At the moment it doesn't seem to be causing an obstruction. I've cut off the projections I mentioned earlier but that hasn't helped. I need to cut away a lot more but that isn't so easy as the plastic moulding in the centre of that bit is quite deep as you can in the pic below. Those prongs belong to this moulding around the heater duct holes (photo from an eBay advert). It looks like, if one removed the screws arrowed, one could remove this piece. On a RHD car, the LH screw may be accessible. I can feel it, but I can't feel the RH screw. What also confuses is the mixing of posts referring to the later models in this thread. They need to be split out into their own thread. Ron B. VK2OTC 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
2nd Jan 2024 2:14am |
RovingCanary Member Since: 20 Dec 2023 Location: Somerset Posts: 79 |
Noticed today the front fan on mine is not blowing 😭. Checked the fuses, all fine got continuity (not yet checked for power at them), no error codes.
5th Feb 2024 8:47pm |
