Home > Technical (L322) > no heater blower
Page 2 of 7 <1234567>
trainmanone
England 2002 Range Rover HSE Td6 Oslo Blue
well temp fix has packed up Big Cry
rear heater works but no front heat .
looks like a strip down of the dash is in order.
Big Cry Big Cry Big Cry Big Cry Big Cry have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #166145 20th Jan 2013 6:18pm
mjdronfield
FFfffffffffff Shocked
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #166150 20th Jan 2013 7:17pm
Jr-auto-electrics
England 2004 Range Rover Vogue Td6 Java Black
Where does that wire go Shocked RANGE ROVER 04 TD6
RANGE ROVER ULTIMATE EDITION 2012
UPGRADE.
MK 4 SATNAV
http://www.flickr.com/photos/jrautoelectrics/
Post #166151 20th Jan 2013 7:40pm
trainmanone
ff sake think i will buy a gallon of petrol and phone my insurance company have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #166161 20th Jan 2013 9:05pm
trainmanone
just put hawkeye on and getting following faults on fuel fired heater 65 park heater message disturbance fault , and glow plug flame detector short circuit to ground.
can any one enlighten me to the remady have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #166162 20th Jan 2013 9:16pm
Jr-auto-electrics
Glow plugs gone in your FBH
£160 for a new one sorry RANGE ROVER 04 TD6
UPGRADE.
MK 4 SATNAV
Post #166164 20th Jan 2013 9:29pm
trainmanone
update...........
just taken top of dash off and head unit out,took cover of motor off and looks like a carbon brush has worn right down on the bottom ,motor now running , question is can you get the carbon bushes as a spare?? or any one got a duff motor with good bushes that i could salvage off have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #166506 22nd Jan 2013 1:57pm
Durham4416
United Kingdom 2003 Range Rover HSE Td6 Zambezi Silver
Sorry to go off topic but before it packed up completely did the blower speed fluctuate, sometimes mine fluctuates when on a bout the 4th light, does it sound like an fsr or a motor problem like yours?
Post #166564 22nd Jan 2013 5:15pm
ebajema
My dad and I used to fix starter motors like that all the time, buy the brushes for 2 or 3 Euro and a bit of work. No clue where to get them in the UK. In Holland we had a few shops that still sold electrical components for prof and hobby. Not sure if those still exist or do exist in the UK.
If you get brushes, make sure you clean the collector (fine emery cloth to clean the collector surface and nail to clean the grooves afterwards). MY 2010 5.0 SC Galway green and sand interior!!
Post #166567 22nd Jan 2013 5:21pm
VaguelyVogue
United Kingdom 2006 Range Rover Vogue Td6 Buckingham Blue
a) Have a search in your yellow pages for somewhere who will rewind alternators or starter motors - they will usually have carbon brushes too (which might require adjusting to size with sandpaper)
b) eBay can be a good source for carbon brushes - but you usually need to know what electric motor they are for or what size they are - again, you can adjust height, width and length down to fit with sandpaper
I would expect a pair of brushes to be a couple of pounds delivered.
Post #166585 22nd Jan 2013 6:32pm
Stormin
2003 Range Rover HSE Td6 Epsom Green
Durham 4416
Im having the same problem, working fine but speeds up and slows down on its own. Its as if a second fan is kicking in somewhere Three things in a blokes life his dog,his car and a Cornish pasty,nothing else matters.
2010 Range Rover Vogue SE Santorini Black, Arabica Aniline seats
Previous cars
1973 Mini 1000
1971 Hillman Avenger
1975 Chrysler Sunbeam
1981 Ford Cortina
1985 Volvo 340
1989 VW Golf
1989 Volvo 240
1991 Volvo 240
1991 Jaguar Soveriegn
1996 BMW 730
2003 Honda CRV
1999 Jaguar Soveriegn
2003 Range Rover HSE Epson Green with Sand trim.
Post #166590 22nd Jan 2013 6:44pm
trainmanone
in reply to the question about speed isue i think it might have done, worth a try only takes half hour to check have a look at wiki at the power vids head unit change . once top of dash and finnishers are off head unit out theres an acsess hole look into this you will see the motor cover three clips one at top and one each side unclip them and remove cover it will come out with a bit of force ( watch the skin on your fingers) once out the motor is in plane view ,turn on fan switch and useing a screw driver play about with the carbon brushes only takes a little bit of movement ,i got sparking and the fan moved then stopped used some contact clener and hay presto its ok at min. if i can source new brushes im hoping to be able to replace them without doing the full strip down,but looking at the hole the motor unit wont fit through the hole unless i do some minor surgury to the hole ie make it bigger. have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #166615 22nd Jan 2013 7:58pm
Durham4416
Sometimes mine works fine but just now and agin when on the medium setting, (about 4th light in the blower) it just fluctuates like a pulsing, was hoping it was just the fsr :s let us know how you get on with the motor
Post #166626 22nd Jan 2013 8:29pm
Durham4416
Could you possibly buy a p38 motor and use the bushings from that? There are lots of cheap ones on eBay
Post #166639 22nd Jan 2013 8:54pm
JohnnyDangerous
England 2002 Range Rover Vogue 4.4 V8 Java Black
2nd hand motor is around £60-90 and there is no need to disconnect the AC, the motor can be removed from the matrix box whilst that is still in the car, I have a good motor with one of the fan blades broken in transit if its any good to someone just cover postage. Weve just done another last week so more failing as time goes on, he almost fell over when qouted by the stealer (auto data gives 14 hours) One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #166643 22nd Jan 2013 8:59pm
