![]() | Home > Technical (L322) > L322 rear subframe replacement |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
There are several on eBay secondhand for @ £250
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1234 ![]() ![]() ![]() |
Wow that is expensive |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8542 ![]() ![]() ![]() |
If it's failed on the rear subframe how bad are the rear of the sills and the rear arches, take off the sill covers and check, it may be a lost cause if there is rot there as well.... Pete
batfink Member Since: 20 Jun 2011 Location: Milton Keynes Posts: 205 ![]() ![]() |
As per Joe90 eBay has this one that looks pretty good at first sight and a decent price:
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 757 ![]() ![]() |
+1 for Haylands advice. At 20 years old this could become a serious money pit.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4334 ![]() ![]() ![]() |
As above. Check for any other rot in the sills and arches (remove sill covers and rear inner wheel arch liners) then make a decision.
bobsin Member Since: 21 May 2015 Location: wolverhampton Posts: 52 ![]() ![]() |
Fixed sills, arches and replaced rear sub-frame (and brake lines) on my 2004. Plenty good steel to weld to when frilly bits cut out. hope that's it for now.......
