![]() | Home > Maintenance & Mods (L322) > Transfer box oil |
A.Pires Member Since: 02 Dec 2016 Location: Seixal Posts: 154 ![]() ![]() ![]() |
I'm not convinced that there is no other oil for the l322 transfer box than the original from Castrol BOT only supplied by Lan Rover.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2651 ![]() ![]() |
I use Ravenol TF0870. |
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 290 ![]() ![]() ![]() |
An other option : https://www.advancedfactors.co.uk/adv903-i...0908-p.asp TDV8 4.4 2012 |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4334 ![]() ![]() ![]() |
Loads of options as above. Ensure it meets the spec as per WM or Handbook and you'll be fine |
gt40 Member Since: 30 Jan 2013 Location: Cape Town Posts: 31 ![]() ![]() ![]() |
The oil recommendations suggested above do not apply to the NV225 transfer case found on the 2002 to 2006 TD6. TF0870 should not be used.
