Home > Maintenance & Mods (L322) > Transfer box oil |
A.Pires Member Since: 02 Dec 2016 Location: Seixal Posts: 145 |
I'm not convinced that there is no other oil for the l322 transfer box than the original from Castrol BOT only supplied by Lan Rover.
1st Aug 2023 1:29am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2469 |
I use Ravenol TF0870. |
1st Aug 2023 3:09am |
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 275 |
An other option : https://www.advancedfactors.co.uk/adv903-i...0908-p.asp TDV8 4.4 2012 |
1st Aug 2023 6:30am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4301 |
Loads of options as above. Ensure it meets the spec as per WM or Handbook and you'll be fine Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
1st Aug 2023 8:50am |
gt40 Member Since: 29 Jan 2013 Location: Cape Town Posts: 31 |
The oil recommendations suggested above do not apply to the NV225 transfer case found on the 2002 to 2006 TD6. TF0870 should not be used.
2nd Aug 2023 12:50am |
