Home > Technical (L405) > Engine stops
GrandadRob
England 2013 Range Rover Vogue SE SDV8 Luxor
Engine stops
Twice recently I have been travelling very slowly/coasting went to move on, the engine has stopped. It takes about three tries to get it going again. Then it’s ok. No problems at speed. Also couple of “reduced performance mode” . This is immediately on starting, turn it off, 30 seconds later all normal. All very odd. My great Indy says he’s never heard of the engine stopping thing. He’s checking the fault codes on Tuesday. 2013 SDV8 4.4 SE Luxor.
1960 Series 2 88 inch diesel.
1955 Series 1 86 inch petrol.
Post #670124 30th Jul 2023 6:06pm
millerj90
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
This may explain it: - LTB01083
Engine Hesitation/Stall At Low Vehicle Speed
A customer may express a concern that at low vehicle speed the engine hesitates or stumbles. In some circumstances as a result of the low vehicle speed the customer may report that the hesitation or stumble has resulted in the engine stalling. The engine will restart by cycling the ignition.
If the engine has stalled the customer may also express a concern that:
• The Touchscreen has changed and is now displaying the 4x4i – Terrain response/4x4 information.
• 'D' is flashing on the Transmission Control Switch (TCS) and Instrument Cluster (IC).
• The charge warning indicator is illuminated.
A technician may find Diagnostic Trouble Code (DTC) P0088-17 (Fuel Rail/System Pressure - Too High - Circuit voltage above threshold) stored in the Powertrain Control Module (PCM).
CAUSE:
Intermittent electrical connection of the fuel pressure sensor wiring harness.
Sorry I couldn’t upload the pdf, but an internet search should locate it.
Post #670129 30th Jul 2023 8:31pm
GrandadRob
Thank you very much. That describes perfectly what happens.
Do you know if there is a fix for this. 2013 SDV8 4.4 SE Luxor.
Post #670134 31st Jul 2023 6:24am
GrandadRob
Thanks Guys I have found all the information I need to give to my Indy tomorrow. 2013 SDV8 4.4 SE Luxor.
Post #670138 31st Jul 2023 7:43am
GrandadRob
I have read all the LR Technical Bulletin. I see that the replacement loom section may be the better way to go.
It is part number LR085463.
I can't currently locate anyone who has this part in stock. Any suggestions would be appreciated. Any idea of price. 2013 SDV8 4.4 SE Luxor.
Post #670157 31st Jul 2023 3:12pm
millerj90
I couldn’t locate the part either. So I disassembled the upper (easily assessable) connector and doused it in Servisol Switch and Contact cleaner.
So far, so good …..
Post #670167 31st Jul 2023 4:08pm
Mikey
Correct repair is a new electrical connector for the rail pressure sensor, which comes with a length of wiring to remove the connector at the top of the cam cover Thumbs Up
When it's available Banging Head
Post #670177 31st Jul 2023 6:42pm
GrandadRob
Thanks Mike, that’s exactly what my Indy said. Britpart.have them, unlike LR. So as soon as it comes, it will be fitted. 2013 SDV8 4.4 SE Luxor.
Post #670287 2nd Aug 2023 7:20am
GrandadRob
Wire fitted. No further problems. 2013 SDV8 4.4 SE Luxor.
Post #672171 28th Aug 2023 3:04pm
Bikeracer
United Kingdom 2014 Range Rover Vogue SE SDV8 Nara Bronze
CAUSE:
Thank you very much for that explanation, my L405 is behaving in exactly that way.
I have sent a copy of your information to my Range Rover man and I hope to get everything sorted in the next few days.
Post #672229 29th Aug 2023 5:50am
