![]() | Home > Technical (L322) > Body Colour Identification |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8379 ![]() ![]() ![]() |
Passenger side strut top gives you the colour.... |
You might need to wipe the dust n dirt off the struts top, but as Pete said... It'll be there sir |
Mike Edwards Member Since: 13 Feb 2021 Location: Northampton Posts: 226 ![]() ![]() ![]() |
Sadly, no stickers or other information on the passenger side strut top on mine. |
TomC-RRV8 Member Since: 18 Sep 2022 Location: Pangbourne Posts: 79 ![]() ![]() |
Put your reg in to www.paintnuts.co.uk it will give you the colour, I have used them on many a vehicle and have been bob on each time. Current
Unfortunately, www.paintnuts.co.uk just shows the colour that is on the registration documents, i.e. black. |
The other way may be to buy the build sheet for your car I did this cost £6 but gives you all the details such as what was spec'd and also colour. It was through
Should get it free from here... did with mine...
That works. Thanks.
lschwarcz Member Since: 18 May 2019 Location: Hillsboro, OR, USA Posts: 273 ![]() ![]() ![]() |
Quick tip for touch-up paints. Get either the small bottle with a brush in the cap or the spray can from the dealer. I tried a couple of the aftermarket brands that claimed to be perfect matches but were not quite right. Bought the spray can from the dealer and it was spot-on!
