Home > Technical (L322) > Body Colour Identification |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8191 |
Passenger side strut top gives you the colour.... Pete
20th Jul 2023 10:18pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
You might need to wipe the dust n dirt off the struts top, but as Pete said... It'll be there sir |
20th Jul 2023 10:45pm |
Mike Edwards Member Since: 13 Feb 2021 Location: Northampton Posts: 226 |
Sadly, no stickers or other information on the passenger side strut top on mine. |
21st Jul 2023 1:22pm |
TomC-RRV8 Member Since: 18 Sep 2022 Location: Pangbourne Posts: 74 |
Put your reg in to www.paintnuts.co.uk it will give you the colour, I have used them on many a vehicle and have been bob on each time. Current
21st Jul 2023 3:07pm |
Unfortunately, www.paintnuts.co.uk just shows the colour that is on the registration documents, i.e. black. |
21st Jul 2023 3:12pm |
The other way may be to buy the build sheet for your car I did this cost £6 but gives you all the details such as what was spec'd and also colour. It was through
21st Jul 2023 3:42pm |
Should get it free from here... did with mine...
21st Jul 2023 5:48pm |
That works. Thanks.
27th Jul 2023 5:00pm |
lschwarcz Member Since: 18 May 2019 Location: Hillsboro, OR, USA Posts: 273 |
Quick tip for touch-up paints. Get either the small bottle with a brush in the cap or the spray can from the dealer. I tried a couple of the aftermarket brands that claimed to be perfect matches but were not quite right. Bought the spray can from the dealer and it was spot-on!
29th Jul 2023 2:50pm |
