Home > Technical (L322) > Body Colour Identification
Mike Edwards
United Kingdom 2013 Range Rover Vogue SE SDV8 Causeway Grey
I need to touch up a couple of areas of paint and wondered how to identify the correct colour/code? I get as far as knowing it is black but suspect there are a number of different blacks to choose from.
Thanks.
Post #669510 20th Jul 2023 9:45pm
Passenger side strut top gives you the colour.... Thumbs Up Pete
Post #669511 20th Jul 2023 10:18pm
You might need to wipe the dust n dirt off the struts top, but as Pete said... It'll be there sir Thumbs Up
Post #669512 20th Jul 2023 10:45pm
Mike Edwards
Sadly, no stickers or other information on the passenger side strut top on mine.
Post #669526 21st Jul 2023 1:22pm
TomC-RRV8
Put your reg in to www.paintnuts.co.uk it will give you the colour, I have used them on many a vehicle and have been bob on each time. Current
2011 4.4TDV8 VSE
1972 MGBGT
Gone
2004 Discovery Landmark 2.5D
2003 Freelander TD4 SE
Post #669530 21st Jul 2023 3:07pm
Mike Edwards
Unfortunately, www.paintnuts.co.uk just shows the colour that is on the registration documents, i.e. black.
Post #669531 21st Jul 2023 3:12pm
TomC-RRV8
The other way may be to buy the build sheet for your car I did this cost £6 but gives you all the details such as what was spec'd and also colour. It was through
https://m.facebook.com/story.php?story_fbi...sn=scwspmo Current
2011 4.4TDV8 VSE
1972 MGBGT
Gone
Post #669533 21st Jul 2023 3:42pm
Should get it free from here... did with mine...
https://www.vindecoderz.com/ Pete
Post #669542 21st Jul 2023 5:48pm
Mike Edwards
That works. Thanks.
Santorini Black.
Post #669952 27th Jul 2023 5:00pm
lschwarcz
United States 2009 Range Rover Autobiography 4.2 SC V8 Bournville
Quick tip for touch-up paints. Get either the small bottle with a brush in the cap or the spray can from the dealer. I tried a couple of the aftermarket brands that claimed to be perfect matches but were not quite right. Bought the spray can from the dealer and it was spot-on!
Good luck!
Larry. 2009 Range Rover L322 Autobiography
Bournville/Ivory
Save lives, give blood.
Post #670056 29th Jul 2023 2:50pm
