Home > Technical (L322) > L322 2009 - rear door won’t open
cb07
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
Hello all,
So far the new car has been great. Slight problem however has occurred! The rear passenger door behind (drivers side) is now shut fast. The lock works, but the door won’t open from inside or outside. Feels like there is no resistance to the handle.
Anyway to get the actual door open? Or is it terminal!
Can the door card be taken off with the door closed to get at the innards?
Any help or pointers appreciated
Cheers
Post #669829 26th Jul 2023 9:25am
Merchy
I have removed door cards but only with the door open...found the below thread info using the search function hope this helps.
https://www.fullfatrr.com/forum/topic58304...or+opening
A good trim tool kit will make the job a lot easier, loads around, and not expensive.
Post #669841 26th Jul 2023 11:29am
