![]() | Home > Technical (L322) > L322 2009 - rear door won’t open |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1236 ![]() ![]() ![]() |
I have removed door cards but only with the door open...found the below thread info using the search function hope this helps.
cb07 Member Since: 09 Feb 2022 Location: Hertfordshire Posts: 48 ![]() ![]() ![]() |
Very late thread update here!
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8554 ![]() ![]() ![]() |
I usually search on eBay for it, it usually has the part number with it, then choose where to get it from...
Looks sort of correct, not sure I want to totally dismantle it as seems a bit complicated!
Ordered that item! Let’s see if it fixes the problem.
All sorted. A doddle once the door was open. New lock mechanism in, absolutely perfect.
jamiej Member Since: 01 Dec 2023 Location: Surrey Posts: 59 ![]() ![]() ![]() |
I replaced my rear door actuator yesterday as well. A little fiddly but not too bad of a job. Well done. |
Yep, absolute doddle with the door open.
