Home > Maintenance & Mods (L322) > First sign of arch rust
Smitch
United Kingdom 2012 Range Rover Westminster TDV8 Stornoway Grey
Spotted this today, took the trim off and it doesn’t look too bad but want an opinion.
What’s the best way to deal with this and is this the beginning of the end for that arch?
Post #669404 19th Jul 2023 1:59pm
JCW
United Kingdom 2012 Range Rover Autobiography TDV8 Sumatra Black
I’d say you’ve caught that well in time - need to remove the inner plastic wheel arch to check behind in the same area, a few different panels join here and damp gets into the seams. I suspect there’ll be similar early stage rust, looks to be all very treatable from that photo though Thumbs Up Jonathan
2007 Defender 90 XS Hardtop
Post #669405 19th Jul 2023 2:09pm
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
Exactly what JCW has stated. Caught in time. Thumbs Up
Post #669411 19th Jul 2023 2:50pm
Sandyt
that was mine by comparison well done catching it early
Post #669418 19th Jul 2023 4:32pm
Discofish
England 2003 Range Rover HSE Td6 Oslo Blue
got to address a similar issue myself and was looking at the only seller who currently make replacement panels for the sill and about died when they quoted £305 per pair.
so as i have access to a metal work shop would it possible for someone on here to post the dimensions, bend angles etc for the sill whilst they are doing a repair so more of us can do the same without being held to ransom to the tune of one arm and one leg.
Thanks in advance
Post #669422 19th Jul 2023 4:43pm
Sandyt
I used these
https://www.ebay.co.uk/itm/194964651357
Post #669425 19th Jul 2023 5:04pm
Sandyt
sorry to hijack your thread but at least you won't be doing all this Thumbs Up Thumbs Up
Post #669426 19th Jul 2023 5:09pm
bobsin
2004 Range Rover Vogue Td6 Epsom Green
Arches
You've caught that well early, this is my '04 before and after I repaired it....
Post #669449 20th Jul 2023 2:48am
Ennoch
Thanks in advance
Someone's had to make the former and get them created, I don't think £300 for a pair of replacement arch panels is unreasonable if it's made in decent steel of a proper thickness.
Post #669465 20th Jul 2023 10:02am
SamThomas
United Kingdom 2003 Range Rover Vogue Td6 Baltic Blue
I would agree with Ennoch.
Part of the £305 (which is not bad IMHO) goes towards measuring/tooling up, workshop time/costs & of course the material itself.
Post #669468 20th Jul 2023 10:23am
KitTheRam
United Kingdom 2009 Range Rover Vogue TDV8 Santorini Black
I noticed my first bit of small bubbling on both rear arches when opening the doors after the wet weather at the weekend, yet to take the plastic panels off but a quick picture from under that area does not look fun. Hoping it’s not too big a job once it’s investigated.
Drivers side:
Passenger side:
 2009 pre-facelift 3.6 TDV8.
Post #669743 24th Jul 2023 10:05pm
KitTheRam
I noticed that my inner wings seem very rusty, especially drivers side, is this as common as the arches going? I know there must be a mutual rust relationship between them…
Post #669794 25th Jul 2023 4:36pm
Snowy90 L322
United Kingdom 2004 Range Rover HSE Td6 Giverny Green
I have this delightful job, havent had the balls to take off the plastic yet!
Post #669797 25th Jul 2023 5:33pm
