![]() | Home > Maintenance & Mods (L322) > First sign of arch rust |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 877 ![]() ![]() ![]() |
I’d say you’ve caught that well in time - need to remove the inner plastic wheel arch to check behind in the same area, a few different panels join here and damp gets into the seams. I suspect there’ll be similar early stage rust, looks to be all very treatable from that photo though |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 ![]() ![]() ![]() |
Exactly what JCW has stated. Caught in time. |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2269 ![]() ![]() ![]() |
Discofish Member Since: 21 Jul 2020 Location: Nottingham Posts: 105 ![]() ![]() ![]() |
got to address a similar issue myself and was looking at the only seller who currently make replacement panels for the sill and about died when they quoted £305 per pair.
I used these
bobsin Member Since: 21 May 2015 Location: wolverhampton Posts: 52 ![]() ![]() |
You've caught that well early, this is my '04 before and after I repaired it....
Ennoch Member Since: 26 Dec 2015 Location: Scotland Posts: 109 ![]() |
Someone's had to make the former and get them created, I don't think £300 for a pair of replacement arch panels is unreasonable if it's made in decent steel of a proper thickness. |
SamThomas Member Since: 12 Nov 2021 Location: South East Posts: 293 ![]() ![]() ![]() |
I would agree with Ennoch.
KitTheRam Member Since: 29 Mar 2022 Location: Essex/Herts Border (originally from Derby) Posts: 431 ![]() ![]() ![]() |
I noticed my first bit of small bubbling on both rear arches when opening the doors after the wet weather at the weekend, yet to take the plastic panels off but a quick picture from under that area does not look fun. Hoping it’s not too big a job once it’s investigated.
I noticed that my inner wings seem very rusty, especially drivers side, is this as common as the arches going? I know there must be a mutual rust relationship between them…
Snowy90 L322 Member Since: 24 Aug 2015 Location: Surrey Posts: 220 ![]() ![]() ![]() |
I have this delightful job, havent had the balls to take off the plastic yet! |
