![]() | Home > Maintenance & Mods (L322) > Removing wing mirror glass |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
Iirc angle the mirror glass inwards then pull hard from the outer edge.
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1214 ![]() ![]() ![]() |
This may help, Atlantic British video showing 'How to change', like Powerful UK, they do have some good informative how to videos. Hope this helps |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7860 ![]() ![]() ![]() |
Yes, gonna need big boy brave pants on for swapping mirror glass… remember doing mine 🤣.
Would it not be easier and safer to remove the mirror cap before changing the glass? |
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 731 ![]() ![]() ![]() |
Cheers all - Glad I didn't continue earlier when I was going red in the face...
Thanks all. Got the old glass off, it cracked and leaked a liquid all over me in the process |
If it's got the two wires it's hot the heater element built in.
Thanks Merchy - any idea what the plug is that goes to it as well? |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 888 ![]() ![]() ![]() |
Likely to be the connector for auto dimming |
Thanks JCW
That will be a much cheaper solution…. But…. I’ve a feeling it might have a slightly different tint, and that would annoy me every time I drove 🤣….
That’s what I did on a previous L322, the price difference just wasn’t worth it to me ![]() 2007 Defender 90 XS Hardtop |
Even in 2016, it was like £40 against £110 if I remember right. 2011 Range Rover Vogue SE 4.4 TDV8
Replacement glass has finally arrived and I’ve swapped over the clip-on mounting bracket…
