![]() | Home > Maintenance & Mods (L322) > EGR Delete |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6768 ![]() ![]() ![]() |
You can remove the EGRs, blank out the spaces where they were with kits from E-Bay, then map them out to stop the EML coming on.
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1484 ![]() ![]() |
This is not advised on the 4.4 TDV8, which depends on the EGR for the emissions control and DPF.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2653 ![]() ![]() |
The BAS link is for the 3.6, not the 4.4.
Red Hot one Member Since: 09 Dec 2018 Location: Herefordshire Posts: 195 ![]() ![]() ![]() |
Just as an aside, If I install the BAS EGR delete on my 3.6 with the blanks installed can it be undone and put back to factory standard if at some point this would become necessary?
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4334 ![]() ![]() ![]() |
Lots of folks are now gutting the DPF and mapping out the EGR on the 4.4TDV8 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
paulwlincs Member Since: 07 Oct 2019 Location: Lincoln Posts: 44 ![]() ![]() ![]() |
I get the code P245A EGR bypass circuit high from memory .
Paul, this sounds like the cooler bypass actuator which is faulty. Has any garage suggested it could be this? It's a very cheap part (LR022783) and maybe looks possible to change without removing the oil cooler?
No I haven’t had any suggestions from the garage I took it too . Thank You for the info I will look into it 2011 tdv8 4.4 vogue Santorini black |
jaguar3 Member Since: 25 Sep 2022 Location: Estonia Posts: 194 ![]() ![]() ![]() |
You need to remove plenum chamber, then you have acess to this valve. But only thing you can do is just connect vacuum gun and check is it physicaly moving or not. However, its a vacuum valve and without any feedback to ECU, so if you have fault code you need to find and check electric solenoid valve first. |
