Home > Maintenance & Mods (L322) > EGR Delete
paulwlincs
EGR Delete
Hi all , I’ve had a lot of EGR error codes and engine management lights and I’ve explored the possibility of getting the EGR deleted .
I’ve been quoted for this from several mapping companies but I’m unsure if I need to blank it off or not .
Also one company said I would need to disconnect the EGR module myself .
Any advice welcome. Has anyone successfully done this .
I have had the EGR looked at but it’s still a problem. 2011 tdv8 4.4 vogue Santorini black
Post #667942 30th Jun 2023 8:59am
You can remove the EGRs, blank out the spaces where they were with kits from E-Bay, then map them out to stop the EML coming on.
BAS do a remap - https://bellautoservices.co.uk/store/rrs-3...-road-use/ Got - 2017 SDV8 Autobiography in Loire Blue
Post #667944 30th Jun 2023 9:06am
garyRR
This is not advised on the 4.4 TDV8, which depends on the EGR for the emissions control and DPF.
If you can share some of the fault codes/issues, the members on here should be able to help identify what the actual resolution is.
It is invariably intake hose related, the seal inside the throttle body union or exhaust sensor down the side of the engine which are the root cause of EGR / DPF / Restricted Performance issues. 2015 Range Rover Autobiography 4.4 SDV8
Post #667945 30th Jun 2023 9:06am
GraemeS
The BAS link is for the 3.6, not the 4.4.
EGR operation is only made inoperative by remapping but the valve still needs to respond to the test and clean cycles so has to remain. Mine's been made inoperative and I'll blank it when I get around to it in case the valve stops sealing.
DPF burns won't be affected by lack of exhaust gas recirculation as the valve is required to be closed during a burn to ensure that all the fuel-rich exhaust goes to the catalytic converter rather than be cycled back through the engine. However I don't know the impact, adverse or otherwise, of soot accumulation in the DPF when the valve is always closed.
Post #667958 30th Jun 2023 12:18pm
Red Hot one
United Kingdom 2009 Range Rover Vogue TDV8 Stornoway Grey
Just as an aside, If I install the BAS EGR delete on my 3.6 with the blanks installed can it be undone and put back to factory standard if at some point this would become necessary?
Will
Post #668005 30th Jun 2023 6:18pm
DrRob
Lots of folks are now gutting the DPF and mapping out the EGR on the 4.4TDV8 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #668006 30th Jun 2023 7:12pm
paulwlincs
I get the code P245A EGR bypass circuit high from memory .
I’m still unconvinced that the EGR can’t be deleted there isn’t anyone though that I’ve seen had it done which is holding me back 😒 2011 tdv8 4.4 vogue Santorini black
Post #668008 30th Jun 2023 8:14pm
garyRR
Paul, this sounds like the cooler bypass actuator which is faulty. Has any garage suggested it could be this? It's a very cheap part (LR022783) and maybe looks possible to change without removing the oil cooler?
Post #668015 30th Jun 2023 9:51pm
paulwlincs
No I haven’t had any suggestions from the garage I took it too . Thank You for the info I will look into it 2011 tdv8 4.4 vogue Santorini black
Post #668030 1st Jul 2023 7:13am
jaguar3
Estonia 2011 Range Rover Vogue SE 4.4 V8 Baltic Blue
You need to remove plenum chamber, then you have acess to this valve. But only thing you can do is just connect vacuum gun and check is it physicaly moving or not. However, its a vacuum valve and without any feedback to ECU, so if you have fault code you need to find and check electric solenoid valve first.
Post #668036 1st Jul 2023 8:06am
