![]() | Home > Technical (L322) > Help me out with the suspension on my 'famous' 4.4TDV8 L322! |
LandyManSam Member Since: 10 Jul 2019 Location: Wild West Ireland Posts: 51 ![]() ![]() ![]() |
That's interesting. What mileage is your truck on, Cola?
I've had a harsh 1-2 upshift since I've had it so may try a reset but not sure why the box doesn't learn over time to smooth out the changes. Only happens on light throttle / low load. 2012 TDV8 Vogue (L322) |
chdavis Member Since: 29 Nov 2021 Location: Washington DC Posts: 44 ![]() ![]() |
Absolutely no reason not to reset adaptations on a high mileage gearbox, just take care to follow the proper adaption drive cycle. Not sure why someone would advise against it but obviously they are not familiar with the ZF 6 or 8 speed autos.
That is crazy - of course you would reset the transmission adaptations after changing the fluid. The viscosity slightly changes overtime as the fluid breaks down and gets old. This is quite literally what the clutch adaptations are adapting. New fluid is obviously a different viscosity than the old fluid, and you must tell the transmission to adapt to that. I have no idea what a megaflush is - it sounds somehow like something I would never do. ZF Lifeguard 6 fluid only, nothing else. Lifeguard 8 if you have the 8 speed ZF. 2012 Range Rover HSE | 2011 Range Rover Autobiography | 2010 Range Rover Sport Supercharged 2020 Tesla Model 3 Performance, 2013 Mercedes-Benz G550, 2008 Ferrari F430, 2007 Volkswagen Touareg V10 TDI |
Why doesn't it adapt over time (self calibration) ? 2012 TDV8 Vogue (L322) |
I don’t know. If the automatic adaptation got it wrong and for whatever reason started pulling back clutch pressures on old/original fluid, really hard shifts and slipping would occur and almost certainly resulting in premature failure. Ergo, probably best to eliminate all that potential issue and adapt one way and let the service tech reset adaptations manually.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2641 ![]() ![]() |
That may be the case for MY17+ vehicles but recalibration of my MY12 shocks certainly recalibrates the system, making them softer or harder depending on the calibration surface. I had to recalibrate several times as the first time the vehicle wasn't moving which resulted in uselessly soft shocks to calibration over ruts and pot-holes that resulted in excessively firm shocks, finally settling on a particular strip of secondary sealed road travelling at 80 kph which provided the best ride given that the shocks were well worn at the time. Last edited by GraemeS on 29th Jun 2023 9:48pm. Edited 1 time in total |
Besides all that discussion, if you think about how the transmission works it’s really just measuring filling times and pressures, then adapting on that. Would be sketchy and too uncertain to let it decide whether fluid is new or not. I would rather instruct it and relearn by way of the drive cycle.
Can you quickly describe your drive calibration routine? How long do uou spend on the surface and describe me more the surface? 2012 Range Rover HSE | 2011 Range Rover Autobiography | 2010 Range Rover Sport Supercharged 2020 Tesla Model 3 Performance, 2013 Mercedes-Benz G550, 2008 Ferrari F430, 2007 Volkswagen Touareg V10 TDI |
I'm not sure how practical the described gearbox re-set procedure is unless you own a very long private road and furthermore I doubt most gearbox service centers or dealerships would have access to roads that alowed this. Again - I still don't understand why the box doesn't adapt in normal driving like most other systems. 2012 TDV8 Vogue (L322) |
A timer display starts when the start button on the IIDtool is pressed and IIRC the timer runs for 20 seconds. I press the start button while driving at my 80 kph and try to maintain the same speed. I've chosen a stretch of bitumen that has a couple of patched areas and is generally uneven, but nothing too drastic.
If you still don’t understand than I recommmed reading the ZF and LR service manuals or just have a clunky auto box. Suit yourself my friend. If you think LR’s is long, you should see the one BMW uses for the same transmission ![]() 2020 Tesla Model 3 Performance, 2013 Mercedes-Benz G550, 2008 Ferrari F430, 2007 Volkswagen Touareg V10 TDI |
This is great. Thank you. I’m using a similar tool (Launch x431) with similar functionality but it sounds like GAP tool is much better for LR. I know that’s true. But I think if I start the calibration and run your described steps, it will work. So that’s very helpful, thank you! 2012 Range Rover HSE | 2011 Range Rover Autobiography | 2010 Range Rover Sport Supercharged 2020 Tesla Model 3 Performance, 2013 Mercedes-Benz G550, 2008 Ferrari F430, 2007 Volkswagen Touareg V10 TDI |
Gap added the function in response to my enquiry if they might be able to provide it at some stage. The tool invokes a standard capability of the CVD module that Gap knew about but hadn't programmed. |
