Home > Maintenance & Mods (L322) > Fitting a DPF sensor to my L322 4.4tdv8
kevinp
What difference has it made?
Post #655900 7th Feb 2023 10:29am
kenneally_mark
Ireland 2012 Range Rover Westminster 4.4 V8 Santorini Black
It's driving much smoother & quicker. None of the hesitation that was there previously
Post #655907 7th Feb 2023 10:55am
kevinp
Post #655908 7th Feb 2023 10:56am
DrRob
Which sensor was it that you replaced? Location etc? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #655947 7th Feb 2023 3:26pm
kenneally_mark
The DPF sensor. It's near the passenger footwell underneath.
Post #655949 7th Feb 2023 3:52pm
AdrianL322
Norway 2012 Range Rover Vogue TDV8 Buckingham Blue
kenneally_mark wrote:
So in my simple learnings from fitting this sensor:
1. Buy genuine - I have no intention of fitting another one again or wasting money on doing it twice
2. Make sure you have two clips to replace the ones that feed into the sensor - see attached photo where I've circled it
3. I was wondering how to reset the DPF readings, after DrRob suggested checking the Workshop Manual I found this explanation on how to reset it: NOTE: If a new diesel particulate filter pressure sensor or hose lines have been installed or incorrectly routed, or any pressure sensor circuit repairs carried out, the engine control module must learn and store the new diesel particulate filter pressure sensor offset value. The following conditions must be met to allow the diesel particulate filter pressure sensor offset value to be learnt and stored: Using the manufacturer approved diagnostic system, clear DTCs from engine control module, then monitor the datalogger signal 'sump oil temperature - measured' ensuring a minimum of 50 degrees C is achieved. Start engine, run above 500rpm for 2 minutes, then a further 30 seconds at idle. Ensure the engine cooling fan is not running. Set vehicle in park and set ignition status to off. Wait 30 seconds for the engine control module to power down, learn and store diesel particulate filter pressure sensor offset value. This process must be carried out six times, to allow a large negative offset value to adapt back to 0 Hpa
* Caveat - I'm not a mechanic and nor do I claim to know too much. I'm operating on learnings & advice from this forum etc
Does changing the sensor make a difference: YES!
Do you know the correct LR part number for the DPF pressure sensor? I see both LR122713 and LR023134 are listed on this site: parts.jaguarlandroverclassic.com
I read somewhere that there is a difference between "AA" and "AB" sensor type aswell?
Also do you have the part number for the two clips you mention?
I have the same fault codes and are concidering to change the sensor. 2012 Range Rover TDV8 4.4
Post #667228 21st Jun 2023 1:52pm
Smitch
United Kingdom 2012 Range Rover Westminster TDV8 Stornoway Grey
Model variants other than the original AA version have different base voltages so throw the readings out completely. In the world of Ford they are interchangeable but for our car they aren’t.
Post #669221 16th Jul 2023 12:27pm
